Ir para o conteúdo principal
DROCON Ninja Camera Replacement
O que você precisa
    1. DROCON Ninja Camera Replacement, Battery: passo 1, imagem 1 %32 DROCON Ninja Camera Replacement, Battery: passo 1, imagem 2 %32 DROCON Ninja Camera Replacement, Battery: passo 1, imagem 3 %32
      • Make sure the drone is powered off before beginning the battery replacement.
      • To turn the drone off, press and hold the black button on the top of the drone until all lights are off.
      • Firmly grasp the battery tab between your thumb and index finger.
      • Pull the battery away from the drone's body
      Pergunte ao FixBot
      Comentar
    1. DROCON Ninja Camera Replacement, Casing: passo 2, imagem 1 %32 DROCON Ninja Camera Replacement, Casing: passo 2, imagem 2 %32 DROCON Ninja Camera Replacement, Casing: passo 2, imagem 3 %32
      • Using a Phillips #00 Screwdriver remove the eight 4mm screws on the bottom of the drone.
      Pergunte ao FixBot
      Comentar
    2. DROCON Ninja Camera Replacement: passo 3, imagem 1 %32 DROCON Ninja Camera Replacement: passo 3, imagem 2 %32
      • Gently pull white casing away from the black bottom casing
      Pergunte ao FixBot
      Comentar
    3. DROCON Ninja Camera Replacement: passo 4, imagem 1 %32 DROCON Ninja Camera Replacement: passo 4, imagem 2 %32 DROCON Ninja Camera Replacement: passo 4, imagem 3 %32
      • Insert the opening tool under one of the black plastic connector slots that connects the circuit-board to the casing.
      • Gently pull the opening tool toward you to disconnect the circuit-board from the plastic casing.
      Pergunte ao FixBot
      Comentar
    1. DROCON Ninja Camera Replacement, Camera: passo 5, imagem 1 %32 DROCON Ninja Camera Replacement, Camera: passo 5, imagem 2 %32 DROCON Ninja Camera Replacement, Camera: passo 5, imagem 3 %32
      • Use a Phillips #00 screwdriver to remove the 5mm screws connecting the front two motor arms to the drone's body.
      • Use your fingers to gently pull the white plastic discs out of the motor arms.
      Pergunte ao FixBot
      Comentar
    2. DROCON Ninja Camera Replacement: passo 6, imagem 1 %32 DROCON Ninja Camera Replacement: passo 6, imagem 2 %32
      • Grasp the motor arm and pull up and away from the drone's body.
      • Repeat this step for the other front motor arm.
      Pergunte ao FixBot
      Comentar
    3. DROCON Ninja Camera Replacement: passo 7, imagem 1 %32 DROCON Ninja Camera Replacement: passo 7, imagem 2 %32 DROCON Ninja Camera Replacement: passo 7, imagem 3 %32
      • Using the Phillips #00 screwdriver, remove the two 3mm screws on the control board.
      Pergunte ao FixBot
      Comentar
    4. DROCON Ninja Camera Replacement: passo 8, imagem 1 %32 DROCON Ninja Camera Replacement: passo 8, imagem 2 %32 DROCON Ninja Camera Replacement: passo 8, imagem 3 %32
      • Using the opening tool flip up the black plastic clamp that holds the camera wire to the circuit board.
      • Gently pull the camera out from the control board.
      Pergunte ao FixBot
      Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 28
Ao todo: 593
