Introdução
This guide will show the steps needed to remove the flight controller. In order to remove the flight controller, the cover will have to be removed first. Removing the flight controller will require disconnecting the wire connections on it.
O que você precisa
With the battery facing you, locate the two tabs on the top and bottom of the battery as shown.
Slowly remove the upper half of the plastic case about halfway. There is a ribbon cable that's connects the cover and the control board.
Follow the ribbon cable to the control board and locate the connector that connects the cable to the control board.
Press the tab on the side of the connector and pull up on the cable.
Continue to remove the shell the rest of the way.
Locate the five ribbon cables that need to be disconnected from the control board.
Locate the red and black battery wires.
Follow the three wires from each motor and the three wires from each LED to where they connect on the control board.
Use a plastic opening tool to remove the glue that covers the motor and LED wires. Use a metal opening tool if necessary.
Desolder the six motor and LED wires where they connect on the flight controller for each arm. Refer to the Desoldering Guide on how to desolder.
Desolder the battery wires.
Locate the ribbon cable that is next to the word "Front" on the flight controller.
Remove the small cable next to the ribbon cable by pinching on the side tab and pulling up on the connector. It has black, red and yellow wires.
Remove the black band from the ribbon cable.
Remove the ribbon cable by pinching on the side tab and pulling up on the connector.
11 outras pessoas executaram este guia.
2Comentários do guia
Very clear and helpful. Thank You.
Excellent with great visuals. Can really see what to do
