Ir para o conteúdo principal
DJI Mini 2 Main Board Replacement
O que você precisa
Vídeo de Apresentação
  1. DJI Mini 2 Main Board  Replacement, Battery: passo 1, imagem 1 %32 DJI Mini 2 Main Board  Replacement, Battery: passo 1, imagem 2 %32
    • Face the DJI Mini 2 away from you so that you are looking at the charging ports.
    • Use your finger to open up the back panel.
    Pergunte ao FixBot
  2. DJI Mini 2 Main Board  Replacement: passo 2, imagem 1 %32 DJI Mini 2 Main Board  Replacement: passo 2, imagem 2 %32
    • Pinch the locking mechanism on the battery to release the lock.
    • Pull the battery straight out of the compartment.
    Pergunte ao FixBot
  3. DJI Mini 2 Main Board  Replacement, Drone Body: passo 3, imagem 1 %32 DJI Mini 2 Main Board  Replacement, Drone Body: passo 3, imagem 2 %32
    • Unfold the wings of the drone.
    • Place the drone upside down on a flat surface.
    • There should be stickers on the device telling you how to unfold the propeller arms.
    Pergunte ao FixBot
  4. DJI Mini 2 Main Board  Replacement: passo 4, imagem 1 %32 DJI Mini 2 Main Board  Replacement: passo 4, imagem 2 %32
    • Remove the four 5 mm J000 screws near each propeller arm.
    Pergunte ao FixBot
  5. DJI Mini 2 Main Board  Replacement: passo 5, imagem 1 %32 DJI Mini 2 Main Board  Replacement: passo 5, imagem 2 %32 DJI Mini 2 Main Board  Replacement: passo 5, imagem 3 %32
    • Flip the drone back over.
    • Use a combination of the opening tool and your fingers to pry open the top panel of the drone along the seams.
    Pergunte ao FixBot
  6. DJI Mini 2 Main Board  Replacement: passo 6, imagem 1 %32 DJI Mini 2 Main Board  Replacement: passo 6, imagem 2 %32
    • Remove the two 5 mm J000 screws located in the battery hatch and near the ports on the back of the drone.
    Pergunte ao FixBot
  7. DJI Mini 2 Main Board  Replacement: passo 7, imagem 1 %32 DJI Mini 2 Main Board  Replacement: passo 7, imagem 2 %32
    • Flip the drone over again.
    • Pry off the bottom panel of the drone using the opening tools and your fingers.
    Pergunte ao FixBot
  8. DJI Mini 2 Main Board  Replacement, Main Board: passo 8, imagem 1 %32 DJI Mini 2 Main Board  Replacement, Main Board: passo 8, imagem 2 %32 DJI Mini 2 Main Board  Replacement, Main Board: passo 8, imagem 3 %32
    • Remove the three 3mm J000 screws on the black plate.
    Pergunte ao FixBot
  9. DJI Mini 2 Main Board  Replacement: passo 9, imagem 1 %32 DJI Mini 2 Main Board  Replacement: passo 9, imagem 2 %32
    • Use your fingers to pull the black plate off to reveal main board.
    Pergunte ao FixBot
  10. DJI Mini 2 Main Board  Replacement: passo 10, imagem 1 %32 DJI Mini 2 Main Board  Replacement: passo 10, imagem 2 %32 DJI Mini 2 Main Board  Replacement: passo 10, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Try to avoid disturbing the blue thermal paste covering two of the large board components. If the paste is disturbed or splotchy in places it may need to be removed and reapplied. For more information refer to the How to Apply Thermal Paste guide.
    • Using ESD Safe Tweezers Blunt Nose, remove the 5 cables attached to the main board.
    Pergunte ao FixBot
  11. DJI Mini 2 Main Board  Replacement: passo 11, imagem 1 %32 DJI Mini 2 Main Board  Replacement: passo 11, imagem 2 %32
    • Use the ESD Safe Tweezers Blunt Nose and your fingers to pull off the main board from the drone carriage.
    Pergunte ao FixBot
Conclusão
4 outras pessoas executaram este guia.
Equipe
UMass Dartmouth, Team F-1, Gurgel Spring 2022 Membro de UMass Dartmouth, Team F-1, Gurgel Spring 2022
UMASSD-GURGEL-S22SFG1
2 Membros
Autoria de 20 guias
2Comentários do guia
I found this mini 2 post interesting, even if i want to do somthing
different.
my goal is to install the old motherboard in newer hardware...
gimbal. IMU board barometer/compass busted after the super
90 deg DJI off function, because of a gust... crash,'i really
LOVE DJI.....NOT!"
then I ask to buy parts from them, then they babble
about warranty.... nope bro we are not selling parts
forget it we want to repair it.... forget it, it's my drone
i rather sledge hammer it on YouTube.
so this is last resort transplanting a board with old
firmware, I don't want to use a new bird with more stupid
chiness software, that has no real bearing of local aeronautical
laws.
not using them otherwise. goodbye DJI
Do never buy a Chinese drone! From crappy company
might look here again
albi - Responder Compartilhar
Great advice, thank you.
mauricio vilchez - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 56
Últimos 30 dias: 209
Ao todo: 9,530
