Ir para o conteúdo principal
DJI Mini 2 Drone Body Replacement
O que você precisa
  1. DJI Mini 2 Drone Body Replacement, Battery: passo 1, imagem 1 %32 DJI Mini 2 Drone Body Replacement, Battery: passo 1, imagem 2 %32
    • Face the DJI Mini 2 away from you so that you are looking at the charging ports.
    • Use your finger to open up the back panel.
    Pergunte ao FixBot
    Comentar
  2. DJI Mini 2 Drone Body Replacement: passo 2, imagem 1 %32 DJI Mini 2 Drone Body Replacement: passo 2, imagem 2 %32
    • Pinch the locking mechanism on the battery to release the lock.
    • Pull the battery straight out of the compartment.
    Pergunte ao FixBot
    Comentar
  3. DJI Mini 2 Drone Body Replacement, Drone Body: passo 3, imagem 1 %32 DJI Mini 2 Drone Body Replacement, Drone Body: passo 3, imagem 2 %32
    • Unfold the wings of the drone.
    • Place the drone upside down on a flat surface.
    • There should be stickers on the device telling you how to unfold the propeller arms.
    Pergunte ao FixBot
    Comentar
  4. DJI Mini 2 Drone Body Replacement: passo 4, imagem 1 %32 DJI Mini 2 Drone Body Replacement: passo 4, imagem 2 %32
    • Remove the four 5 mm J000 screws near each propeller arm.
    Pergunte ao FixBot
    Comentar
  5. DJI Mini 2 Drone Body Replacement: passo 5, imagem 1 %32 DJI Mini 2 Drone Body Replacement: passo 5, imagem 2 %32 DJI Mini 2 Drone Body Replacement: passo 5, imagem 3 %32
    • Flip the drone back over.
    • Use a combination of the opening tool and your fingers to pry open the top panel of the drone along the seams.
    Pergunte ao FixBot
    Comentar
  6. DJI Mini 2 Drone Body Replacement: passo 6, imagem 1 %32 DJI Mini 2 Drone Body Replacement: passo 6, imagem 2 %32
    • Remove the two 5 mm J000 screws located in the battery hatch and near the ports on the back of the drone.
    Pergunte ao FixBot
    Comentar
  7. DJI Mini 2 Drone Body Replacement: passo 7, imagem 1 %32 DJI Mini 2 Drone Body Replacement: passo 7, imagem 2 %32
    • Flip the drone over again.
    • Pry off the bottom panel of the drone using the opening tools and your fingers.
    Pergunte ao FixBot
    Comentar
Conclusão
13 outras pessoas executaram este guia.
Jacob Matos
Membro desde: 03/25/22
1.613 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team F-1, Gurgel Spring 2022 Membro de UMass Dartmouth, Team F-1, Gurgel Spring 2022
UMASSD-GURGEL-S22SFG1
2 Membros
Autoria de 20 guias
3Comentários do guia
Where to buy a new drone body ?
Loïc Sarda - Responder Compartilhar
Same Q. Where to buy drone body? Please email me. Thanks
Ruud - Responder Compartilhar
Look for it on Google directly or in Amazon there are websites dedicated to sell the hole body parts
Pedro Burgos - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 10
Últimos 7 dias: 67
Últimos 30 dias: 335
Ao todo: 12,275
