Introdução
This guide is going to show you an easy way to replace the turning band in you Crosley CR42. So you can enjoy your LP sooner rather than later.
O que você precisa
Check troubleshooting wiki to make sure you aren't doing way more work than you have to!
If you believe the band may be broken or out of place, start by unplugging the record player.
1Comentário do guia
My CR42 has a plastic piece that will not let me simply pull the turntable off. I don't want to try to hard to break it, but I also don't know how to get it off to replace the band.
