Ir para o conteúdo principal
Contixo V9 Motherboard Replacement
O que você precisa
  1. Contixo V9 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 Contixo V9 Motherboard Replacement, Motherboard: passo 1, imagem 2 %32
    • Find the separation line between the front and back side of the device on the outer edge of the tablet.
    • Use the plastic opening tool to pry apart the tablet, lifting the face off.
  2. Contixo V9 Motherboard Replacement: passo 2, imagem 1 %32 Contixo V9 Motherboard Replacement: passo 2, imagem 2 %32 Contixo V9 Motherboard Replacement: passo 2, imagem 3 %32
    • Remove the three screws along the perimeter of the motherboard using the Phillips #000 screwdriver to unscrew.
  3. Contixo V9 Motherboard Replacement: passo 3, imagem 1 %32 Contixo V9 Motherboard Replacement: passo 3, imagem 2 %32 Contixo V9 Motherboard Replacement: passo 3, imagem 3 %32
    • Locate the three golden ribbons along the perimeter of the motherboard.
    • There are two dark tabs; pull each away from the cream connection port. Once tabs are in open position remove the gold ribbon.
    • Flip up the dark tab and pull the gold ribbon away.
    • Do not pull the the cables harshly as it could rip the ribbon.
    • Reference this guide for more help with attaching or detaching cables.
  4. Contixo V9 Motherboard Replacement: passo 4, imagem 1 %32 Contixo V9 Motherboard Replacement: passo 4, imagem 2 %32 Contixo V9 Motherboard Replacement: passo 4, imagem 3 %32
    • Locate the battery on the opened tablet.
    • Use the spudger or one of the blue iFixit tools to lift the battery from the base of the tablet.
    • It is possible to use your hand to pry the battery away from the base of the tablet but not recommended.
  5. Contixo V9 Motherboard Replacement: passo 5, imagem 1 %32 Contixo V9 Motherboard Replacement: passo 5, imagem 2 %32 Contixo V9 Motherboard Replacement: passo 5, imagem 3 %32
    • Detach the motherboard from the battery by pressing the soldering tip tool to each of the three connection points.
    • Exercise caution when desoldering the battery.
    • The tool located in the pictures is not the soldering tip tool but rather used for reference of where to detach.
    • Reference this guide for more help with soldering and desoldering the connections.
  6. Contixo V9 Motherboard Replacement: passo 6, imagem 1 %32
    • Remove the motherboard from the base of the device. Switch with replacement.
Conclusão
Janiya M.
Membro desde: 09/12/23
133 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 109
