Ir para o conteúdo principal
Conair Infiniti Pro Model 259NP On/Off Button Replacement
O que você precisa
  1. Conair Infiniti Pro Model 259NP On/Off Button Replacement, Back Panel: passo 1, imagem 1 %32
    • Caution: Unplug the hair dryer before attempting this guide. Leaving the device plugged in may result in electrocution and damage to the device.
    • Hold the hair dryer by the handle so that the back panel faces up.
    Pergunte ao FixBot
    Comentar
  2. Conair Infiniti Pro Model 259NP On/Off Button Replacement: passo 2, imagem 1 %32 Conair Infiniti Pro Model 259NP On/Off Button Replacement: passo 2, imagem 2 %32
    • Remove the two 15.875 mm Phillips #2 screws from the back panel.
    Pergunte ao FixBot
    Comentar
  3. Conair Infiniti Pro Model 259NP On/Off Button Replacement: passo 3, imagem 1 %32 Conair Infiniti Pro Model 259NP On/Off Button Replacement: passo 3, imagem 2 %32 Conair Infiniti Pro Model 259NP On/Off Button Replacement: passo 3, imagem 3 %32
    • Starting from where the cord attaches to the handle, pull apart the two plastic panels.
    • Continue separating the back panel, working along the seam.
    • With moderate force, completely remove the back panel from the hair dryer.
    Pergunte ao FixBot
    Comentar
  4. Conair Infiniti Pro Model 259NP On/Off Button Replacement, Fan Motor Assembly: passo 4, imagem 1 %32 Conair Infiniti Pro Model 259NP On/Off Button Replacement, Fan Motor Assembly: passo 4, imagem 2 %32
    • Hold the hair dryer by the nozzle so that the handle points to the left.
    • Remove the two 1-inch Phillips #2 screws from the back of the fan motor.
    Pergunte ao FixBot
    Comentar
  5. Conair Infiniti Pro Model 259NP On/Off Button Replacement: passo 5, imagem 1 %32 Conair Infiniti Pro Model 259NP On/Off Button Replacement: passo 5, imagem 2 %32 Conair Infiniti Pro Model 259NP On/Off Button Replacement: passo 5, imagem 3 %32
    • Caution: If you recently used the hair dryer, wait at least 10 minutes before attempting this step. The heating element may still be very hot and can cause serious burns.
    • Pull on the back of the fan motor to gently lift the motor out of the hair dryer.
    • Lift the attached electrical wiring and heat shield completely out of the hair dryer.
    Pergunte ao FixBot
    Comentar
  6. Conair Infiniti Pro Model 259NP On/Off Button Replacement, On/Off Button: passo 6, imagem 1 %32
    • Caution: Do not attempt to open or tamper with the capacitor. You may suffer severe electrical shocks.
    • Hold the electrical switches so that the wires are facing upwards.
    Pergunte ao FixBot
    Comentar
  7. Conair Infiniti Pro Model 259NP On/Off Button Replacement: passo 7, imagem 1 %32
    • Focus on the button directly next to the cylindrical capacitor.
    • Desolder the button at the circled locations.
    • New line.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Timothy Lo
Membro desde: 04/22/14
1.214 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 10-58, Amido Spring 2014 Membro de Cal Poly, Team 10-58, Amido Spring 2014
CPSU-AMIDO-S14S10G58
4 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 14
Últimos 30 dias: 62
Ao todo: 9,151
