Ir para o conteúdo principal
Comfort Zone CZ6C Switch Replacement
O que você precisa
    1. Comfort Zone CZ6C Switch Replacement, Switch: passo 1, imagem 1 %32 Comfort Zone CZ6C Switch Replacement, Switch: passo 1, imagem 2 %32 Comfort Zone CZ6C Switch Replacement, Switch: passo 1, imagem 3 %32
      • Make sure to unplug the Comfort Zone CZ6C before cutting any wires.
      • Before replacing your switch, learn how to solder using the How To Solder and Desolder Connections Guide.
      • Start with the fan on its back. Unscrew the back panel to expose the internal wiring.
      Pergunte ao FixBot
      Comentar
    2. Comfort Zone CZ6C Switch Replacement: passo 2, imagem 1 %32 Comfort Zone CZ6C Switch Replacement: passo 2, imagem 2 %32
      • Remove the plastic cover on the switch by pulling it apart from the the back panel.
      Pergunte ao FixBot
      Comentar
    3. Comfort Zone CZ6C Switch Replacement: passo 3, imagem 1 %32
      • Use the soldering iron with caution. Don't touch the tip of the soldering iron to avoid the risk of injury.
      • This step can be made easier with the help of a partner to hold the wiring while you desolder the connection.
      • Disconnect the gray power wire from the switch by desoldering the connection.
      Pergunte ao FixBot
      Comentar
    4. Comfort Zone CZ6C Switch Replacement: passo 4, imagem 1 %32 Comfort Zone CZ6C Switch Replacement: passo 4, imagem 2 %32
      • Cut the green and yellow wire as close to the switch connection as possible.
      Pergunte ao FixBot
      Comentar
    5. Comfort Zone CZ6C Switch Replacement: passo 5, imagem 1 %32 Comfort Zone CZ6C Switch Replacement: passo 5, imagem 2 %32 Comfort Zone CZ6C Switch Replacement: passo 5, imagem 3 %32
      • Strip the green and yellow wire about two centimeters from where it was just cut.
      Pergunte ao FixBot
      Comentar
    6. Comfort Zone CZ6C Switch Replacement: passo 6, imagem 1 %32 Comfort Zone CZ6C Switch Replacement: passo 6, imagem 2 %32 Comfort Zone CZ6C Switch Replacement: passo 6, imagem 3 %32
      • Unscrew the switch from the back panel and remove it.
      Pergunte ao FixBot
      Comentar
    7. Comfort Zone CZ6C Switch Replacement: passo 7, imagem 1 %32 Comfort Zone CZ6C Switch Replacement: passo 7, imagem 2 %32 Comfort Zone CZ6C Switch Replacement: passo 7, imagem 3 %32
      • After replacing the switch, resolder the gray power cord, the green wire, and the yellow wire.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
James Abundis
Membro desde: 04/08/15
169 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 17-5, Forte Spring 2015 Membro de Cal Poly, Team 17-5, Forte Spring 2015
CPSU-FORTE-S15S17G5
4 Membros
Autoria de 25 guias
1Comentário do guia
I need a replacement switch for a Comfort Zone CZ40 heater. Can you help?
Michael Drasic - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 39
Ao todo: 2,824
