Ir para o conteúdo principal
ColecoVision Controller Port Replacement
O que você precisa
  1. ColecoVision Controller Port Replacement, Controller Port: passo 1, imagem 1 %32
    • Flip the ColecoVision over with the pegs facing the ceiling.
    • Remove the eight 15mm screws holding the bottom of the ColecoVision in place using the Phillips #1 screwdriver.
    Pergunte ao FixBot
    Comentar
  2. ColecoVision Controller Port Replacement: passo 2, imagem 1 %32 ColecoVision Controller Port Replacement: passo 2, imagem 2 %32
    • Carefully remove the bottom of the ColecoVision out of the top.
    • I would recommend running a metal spudger along the rim of the case to remove the bottom.
    Pergunte ao FixBot
    Comentar
  3. ColecoVision Controller Port Replacement: passo 3, imagem 1 %32 ColecoVision Controller Port Replacement: passo 3, imagem 2 %32
    • Remove the two 15mm screws holding the casing in place using the Phillips #1 screwdriver.
    • Remove the casing and put it to the side.
    Pergunte ao FixBot
    Comentar
  4. ColecoVision Controller Port Replacement: passo 4, imagem 1 %32 ColecoVision Controller Port Replacement: passo 4, imagem 2 %32
    • Remove the two 15mm screws on the motherboard with a Phillips #1 screwdriver.
    • Pull the entire motherboard towards the back of the system and carefully lift the entire motherboard.
    Pergunte ao FixBot
    Comentar
  5. ColecoVision Controller Port Replacement: passo 5, imagem 1 %32 ColecoVision Controller Port Replacement: passo 5, imagem 2 %32 ColecoVision Controller Port Replacement: passo 5, imagem 3 %32
    • Flip the motherboard over and locate the two controller ports.
    • Using a soldering iron, desolder the controller ports.
    • Refer to this soldering technique guide for reference.
    • After waiting for controller ports to cool down, flip motherboard back over and carefully lift controller ports to remove.
    Pergunte ao FixBot
    Comentar
Conclusão
Bobby
Membro desde: 10/17/18
380 Reputação
Autoria de 2 guias
Equipe
UW Tacoma, Team S1-G2, Rose Fall 2018 Membro de UW Tacoma, Team S1-G2, Rose Fall 2018
UWT-ROSE-F18S1G2
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 40
Ao todo: 1,456
