Ir para o conteúdo principal
Coil Zipper Slider Replacement
O que você precisa
  1. Coil Zipper Slider Replacement, Gather materials: passo 1, imagem 1 %32 Coil Zipper Slider Replacement, Gather materials: passo 1, imagem 2 %32 Coil Zipper Slider Replacement, Gather materials: passo 1, imagem 3 %32
    • Gather tools and the two pieces required for a coil slider replacement:
    • A replacement slider that is the right size and style
    • Reference the Zipper Identification guide to confirm the appropriate replacement piece.
    • A coil top stop in the correct size
    • Coil top stops look like a small metal claw with a flat back and three prongs (one on one side and two on the other).
  2. Coil Zipper Slider Replacement, Locate the top stop: passo 2, imagem 1 %32 Coil Zipper Slider Replacement, Locate the top stop: passo 2, imagem 2 %32 Coil Zipper Slider Replacement, Locate the top stop: passo 2, imagem 3 %32
    • Unzip the zipper.
    • Locate the top stop at the top of the zipper on the side with the slider.
    • The top stop is a piece of plastic or metal that keeps the slider from coming off the top of the zipper.
    • Peel back any fabric that is covering the top stop.
    • Wear safety glasses to protect from projectile pieces.
    • Use end nippers or flush cutters to remove the top stop.
    • To avoid cutting the zipper tape, position the nippers to cut off only the very edge of the stop, then peel away the rest of the stop from the zipper tape.
    • Use a lighter to singe frayed or damaged zipper tape.
    • Slide the damaged zipper slider up and off the zipper tape.
    • Discard the zipper slider responsibly.
    • Making sure the new slider is oriented correctly, slide it onto the zipper tape.
    • Patagonia Repair Tech Tip: Maneuver the slider as if parallel parking a car. Start at an angle, back it onto the zipper tape, and then straighten out. This step can take practice, patience, and a little muscle!
    • Once the slider is on the zipper, test zipping up the jacket to make sure it's the right slider type and that the issue is fixed.
    • Place the top stop on the flat, tape side of the zipper, aligning the double-prong side of the stop to face the jacket and the single-prong side to face the zipper teeth.
    • Slide the single-prong beneath the first or second tooth at the top of the zipper tape.
    • Push the double-prongs through the zipper tape so they emerge on the opposite side, on the inside of the coil.
    • Use pliers to bend the prongs of the stop inward, clamping them around the zipper coil. The prongs will grab into the coil, securing it in place.
    • Check that the new stop effectively prevents the new slider from coming off the zipper.
Linha de Chegada
22 outras pessoas executaram este guia.
Brittany McCrigler
Membro desde: 03/05/12
90.451 Reputação
Autoria de 142 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.629 guias
11Comentários do guia
Where do I get the zipper stop????
Jason Heimink - Responder
How do you find the size slider(in my case 5 millimetres) and also the right size teeth that will fit into the zipper.
bbehrhorst - Responder
I used this Guide to replace the zipper slide on my wife's favorite Disney fleece jacket. I purchased my slide and the stop online. Since I'm not sure about the rules on posting vendor's info, I will say GOOGLE "nylon coil zipper slide". You can have your "zippershipped" right to your door.
kasten39828 - Responder
AWESOME! Thanks for the pointers - I’m ready for tomorrow’s powder day!!!!
Jenny - Responder
Great now how ! thank’s :)
Robert Fyfe - Responder
Comentar
Visualizações:
Últimas 24 horas: 42
Últimos 7 dias: 325
Últimos 30 dias: 1,218
Ao todo: 110,767
