Ir para o conteúdo principal
Coby KYROS MID7125 Side Lock Button Replacement
O que você precisa
  1. Coby KYROS MID7125 Side Lock Button Replacement, Side Lock Button: passo 1, imagem 1 %32
    • Begin by removing back panel using the large opening tool.
    Pergunte ao FixBot
    Comentar
  2. Coby KYROS MID7125 Side Lock Button Replacement: passo 2, imagem 1 %32 Coby KYROS MID7125 Side Lock Button Replacement: passo 2, imagem 2 %32 Coby KYROS MID7125 Side Lock Button Replacement: passo 2, imagem 3 %32
    • Remove the connection of all of the ribbon cables connected to the motherboard of the device using the Plastic Spudger.
    Pergunte ao FixBot
    Comentar
  3. Coby KYROS MID7125 Side Lock Button Replacement: passo 3, imagem 1 %32
    • Use plastic Spudger to remove the battery off of the panels and and leave it unconnected until the device is being put back together.
    • Review Battery Replacement for details on how to remove battery.
    Pergunte ao FixBot
    Comentar
  4. Coby KYROS MID7125 Side Lock Button Replacement: passo 4, imagem 1 %32 Coby KYROS MID7125 Side Lock Button Replacement: passo 4, imagem 2 %32
    • Using the philips head screw driver size PH0, unscrew the screws holding the mother board to the device.
    Pergunte ao FixBot
    Comentar
  5. Coby KYROS MID7125 Side Lock Button Replacement: passo 5, imagem 1 %32
    • Using the plastic Spudger, pop the mother board out of place to expose the broken button piece.
    • Be sure to not pull the mother board out to much, some of the soldered wired connections may break.
    Pergunte ao FixBot
    Comentar
  6. Coby KYROS MID7125 Side Lock Button Replacement: passo 6, imagem 1 %32
    • Use the plastic Spudger to remove broken power button, and then pop in new power button after removal.
    • Reverse steps 1-5 to reassemble.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
UMass Dartmouth, Team 5-2, Martin Fall 2016 Membro de UMass Dartmouth, Team 5-2, Martin Fall 2016
UMASSD-MARTIN-F16S5G2
3 Membros
Autoria de 10 guias
1Comentário do guia
For people wondering: Yes, this does work on a MID7120, because the MID7120's board is similar to the MID7125's board. Also, where can I get switches similar to these? My MID7120 is missing the switch so I can't turn it on.
KineTheFish - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 23
Ao todo: 467
