Ir para o conteúdo principal
Coby Kyros MID7125 Battery Replacement
O que você precisa
  1. Coby Kyros MID7125 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Use iFixit plastic opening tool to make small opening in the side of the device, and continue opening back panel.
    Pergunte ao FixBot
    Comentar
  2. Coby Kyros MID7125 Battery Replacement: passo 2, imagem 1 %32
    • Locate battery. The battery is the silver coated square shaped device on the top of the motherboard.
    Pergunte ao FixBot
    Comentar
  3. Coby Kyros MID7125 Battery Replacement: passo 3, imagem 1 %32
    • There is a small ribbon cable located under the battery. running from the volume buttons underneath the batter to main logic board.
    Pergunte ao FixBot
    Comentar
  4. Coby Kyros MID7125 Battery Replacement: passo 4, imagem 1 %32
    • Knowing the location the ribbon cable, use plastic spudger to pry off battery.
    Pergunte ao FixBot
    Comentar
  5. Coby Kyros MID7125 Battery Replacement: passo 5, imagem 1 %32
    • After the battery is free from the logic board, find the positive and negative wires that connect the battery to the motherboard
    Pergunte ao FixBot
    Comentar
  6. Coby Kyros MID7125 Battery Replacement: passo 6, imagem 1 %32
    • Using a soldering gun, heat up both soldering points.
    • Remove wires from logic board
    • Clean up soldering joints with a desoldering sucker
    • Solder the new battery wires to the same soldering points as the old battery
    • Reverse steps 1-5 to put device back together
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Ryan
Membro desde: 10/20/16
108 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 5-2, Martin Fall 2016 Membro de UMass Dartmouth, Team 5-2, Martin Fall 2016
UMASSD-MARTIN-F16S5G2
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 26
Ao todo: 650
