Ir para o conteúdo principal
ClickN Kids Tablet Battery Replacement
O que você precisa
  1. ClickN Kids Tablet Battery Replacement, Battery: passo 1, imagem 1 %32
    Pergunte ao FixBot
    Comentar
  2. ClickN Kids Tablet Battery Replacement: passo 2, imagem 1 %32
    • Using the iFix it opening tool, pry battery apart from back side of tablet.
    • The battery is connected to the back side by a strong adhesive.
    • The battery may bend during this process.
    • Be careful not to allow the battery to bend any more than necessary. Battery acid leakage is possible.
    • Be careful not to damage the wires or the black tab attached to the battery.
    Pergunte ao FixBot
    Comentar
  3. ClickN Kids Tablet Battery Replacement: passo 3, imagem 1 %32 ClickN Kids Tablet Battery Replacement: passo 3, imagem 2 %32 ClickN Kids Tablet Battery Replacement: passo 3, imagem 3 %32
    • Gently remove tape from the side of the battery connecting to wires and circuits.
    Pergunte ao FixBot
    Comentar
  4. ClickN Kids Tablet Battery Replacement: passo 4, imagem 1 %32 ClickN Kids Tablet Battery Replacement: passo 4, imagem 2 %32 ClickN Kids Tablet Battery Replacement: passo 4, imagem 3 %32
    • Desolder wires connecting battery to motherboard, using contact points found on motherboard.
    • Have someone who is skilled in soldering to perform this step.
    • Be careful not to destroy the motherboard or other parts of device.
    Pergunte ao FixBot
    Comentar
Conclusão
5 outras pessoas executaram este guia.
Kevin Finney
Membro desde: 03/22/15
562 Reputação
Autoria de 4 guias
Equipe
Baylor, Team 4-4, Williams Spring 2015 Membro de Baylor, Team 4-4, Williams Spring 2015
BU-WILLIAMS-S15S4G4
3 Membros
Autoria de 8 guias
3Comentários do guia
Como puedo conseguir el repuesto de mi tabletas epik
Reyshaliz - Responder Compartilhar
A little then moderate skill is necessary if you are somewhat mechanically inclined shouldn't be too problematic. But as far as this gentleman's directions and steps perform the task with no problems and tablet works now. Thank you Kevin Finney and three others my four-year-old daughter Hazel is happy again thanks to you.
Collins Hill
Great Smoky Mountains , TN.
Elivia Hill - Responder Compartilhar
I think these are great instructions for fixing this issue!
If you'd be interested in going a step further…I've been trying to find out how to safely remove the charge port! I know how to solder the replacement onto the board but I can't confirm the best way to detach the old port!?
My god daughter would appreciate another video! :)
JenBcute - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 36
Ao todo: 5,265
