Introdução
This guide is a repair manual for the touch screen on the Chromo Noria. If your screen is broken or needs repair for any reason, this guide will take you through the necessary steps to repair it. Although this guide may look long, you can fix it!
O que você precisa
Insert your Plastic Opening Tool into the crease between the front panel and back panel.
Slide the Opening Tool around the entire device. As you progress, you should see the device open.
Place your finger at the end of the tape closest to the battery.
Peel the tape towards the flex cables to free the battery wires.
Using a Phillips #00 Precision Screwdriver, remove the three 3mm screws by turning the screwdriver counter-clockwise.
Apply downward pressure to each of the clips that hold the touchscreen to the plastic surround.
Work your way around the device in a clockwise motion as you progress.
Uma outra pessoa concluiu este guia.
