Ir para o conteúdo principal
Ceiling Fan Light Fixture Replacement
O que você precisa
    1. Ceiling Fan Light  Fixture Replacement, Light Fixture: passo 1, imagem 1 %32 Ceiling Fan Light  Fixture Replacement, Light Fixture: passo 1, imagem 2 %32 Ceiling Fan Light  Fixture Replacement, Light Fixture: passo 1, imagem 3 %32
      • Working with electrical wires could lead to electrocution.
      • Find your circuit breaker panel and turn off the breaker that corresponds to your ceiling lights.
      • Do this by pushing it to the right.
      • Also flip your light switch to off.
      Pergunte ao FixBot
      Comentar
    2. Ceiling Fan Light  Fixture Replacement: passo 2, imagem 1 %32 Ceiling Fan Light  Fixture Replacement: passo 2, imagem 2 %32
      • Remove the two 1.4 mm Phillips head screws that hold the fixture to the fan itself.
      • Once loose, pull down to expose the two connecting wires.
      Pergunte ao FixBot
      Comentar
    3. Ceiling Fan Light  Fixture Replacement: passo 3, imagem 1 %32 Ceiling Fan Light  Fixture Replacement: passo 3, imagem 2 %32 Ceiling Fan Light  Fixture Replacement: passo 3, imagem 3 %32
      • Disconnect these wires by twisting the caps in a counter-clockwise direction.
      • You only need to disconnect the wires coming from the lighting fixture.
      • Once both caps are removed, simply pull the wires apart to remove the fixture.
      Pergunte ao FixBot
      Comentar
    4. Ceiling Fan Light  Fixture Replacement: passo 4, imagem 1 %32 Ceiling Fan Light  Fixture Replacement: passo 4, imagem 2 %32
      • Loosen the nut holding the ceiling fan piece to the lighting fixture.
      • This step may require a crescent wrench if finger force is not enough.
      Pergunte ao FixBot
      Comentar
    5. Ceiling Fan Light  Fixture Replacement: passo 5, imagem 1 %32
      • Pull upwards to remove the fan piece that holds the light fixture.
      • Your model may require you to twist this piece in a counter-clockwise motion to remove.
      Pergunte ao FixBot
      Comentar
    6. Ceiling Fan Light  Fixture Replacement: passo 6, imagem 1 %32
      • Switch out the old fixture with your new fixture by doing the last two steps in reverse order.
      Pergunte ao FixBot
      Comentar
    7. Ceiling Fan Light  Fixture Replacement: passo 7, imagem 1 %32 Ceiling Fan Light  Fixture Replacement: passo 7, imagem 2 %32
      • To connect your new fixture, locate the black wire from your light and the colored wire from the fan.
      • Be sure to attached the colored wires to each other, and white wires to each other. (Positive-Positive, Negative-Negative)
      • Twist these together. Do the same with the two white wires.
      Pergunte ao FixBot
      Comentar
    8. Ceiling Fan Light  Fixture Replacement: passo 8, imagem 1 %32 Ceiling Fan Light  Fixture Replacement: passo 8, imagem 2 %32
      • Your new light fixture should come with replacement caps. Twist these in a clockwise motion over your wire ends to ensure connection.
      • The old caps work just as well for this if you were not given new ones.
      Pergunte ao FixBot
      Comentar
    9. Ceiling Fan Light  Fixture Replacement: passo 9, imagem 1 %32
      • Be sure to neatly tuck in all wires when re-attaching the fixture.
      • Failure to do this will result in not being able to correctly close the gap and put in the screws.
      Pergunte ao FixBot
      Comentar
    10. Ceiling Fan Light  Fixture Replacement: passo 10, imagem 1 %32
      • Flip your breaker back on, turn on your light switch, and enjoy your new lights!
      Pergunte ao FixBot
      Comentar
Conclusão
12 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 14-1, Green Fall 2015 Membro de Cal Poly, Team 14-1, Green Fall 2015
CPSU-GREEN-F15S14G1
4 Membros
Autoria de 4 guias
11Comentários do guia
Amazingly instructive, informative and concise. Brilliant.
Jeanie Bolin-Moore - Responder Compartilhar
It's awesome
Nandish Reddy - Responder Compartilhar
Just what I needed. Thanks.
bob.mohler - Responder Compartilhar
Does it have remote control??
ceiling fan manufacturers in india
Abhijeet Khole - Responder Compartilhar
Could someone provide the name of the light fixture used in the demonstration?
THOMAS DUFF - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 9
Últimos 7 dias: 33
Últimos 30 dias: 133
Ao todo: 37,324
