Ir para o conteúdo principal
Canon Pixma MP480 Data Port Replacement
O que você precisa
    1. Canon Pixma MP480 Data Port Replacement, Rear and Side Panel: passo 1, imagem 1 %32 Canon Pixma MP480 Data Port Replacement, Rear and Side Panel: passo 1, imagem 2 %32
      • Remove the two 7.9 mm screws using a Phillips #1 screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Canon Pixma MP480 Data Port Replacement: passo 2, imagem 1 %32
      • Lift up the back cover to remove it.
      • You may need to lift firmly as it requires quite a bit of force.
      Pergunte ao FixBot
      Comentar
    3. Canon Pixma MP480 Data Port Replacement: passo 3, imagem 1 %32
      • Open the front tray.
      Pergunte ao FixBot
      Comentar
    4. Canon Pixma MP480 Data Port Replacement: passo 4, imagem 1 %32 Canon Pixma MP480 Data Port Replacement: passo 4, imagem 2 %32
      • Open the scanner compartment.
      • Make sure the blue lever locks into place to keep the compartment open.
      Pergunte ao FixBot
      Comentar
    5. Canon Pixma MP480 Data Port Replacement: passo 5, imagem 1 %32 Canon Pixma MP480 Data Port Replacement: passo 5, imagem 2 %32
      • Remove the blue lever from its slot by pushing it back and twisting clockwise.
      • Close the scanner compartment and cover.
      Pergunte ao FixBot
      Comentar
    6. Canon Pixma MP480 Data Port Replacement: passo 6, imagem 1 %32 Canon Pixma MP480 Data Port Replacement: passo 6, imagem 2 %32
      • Pry open the side cover with the plastic opening tool.
      Pergunte ao FixBot
      Comentar
    7. Canon Pixma MP480 Data Port Replacement: passo 7, imagem 1 %32 Canon Pixma MP480 Data Port Replacement: passo 7, imagem 2 %32
      • Flip the printer over so that the bottom of the printer is facing you.
      • Use the plastic opening tool to remove the corner of the side panel from the plastic pin.
      Pergunte ao FixBot
      Comentar
    8. Canon Pixma MP480 Data Port Replacement: passo 8, imagem 1 %32 Canon Pixma MP480 Data Port Replacement: passo 8, imagem 2 %32
      • Use the plastic opening tool to loosen the side panel from the bottom of the printer.
      Pergunte ao FixBot
      Comentar
    1. Canon Pixma MP480 Data Port Replacement, LCD: passo 9, imagem 1 %32 Canon Pixma MP480 Data Port Replacement, LCD: passo 9, imagem 2 %32
      • Using the plastic opening tool, pry off the top cover of the LCD assembly.
      • Pry around the front and side edges for the easiest removal.
      Pergunte ao FixBot
      Comentar
    2. Canon Pixma MP480 Data Port Replacement: passo 10, imagem 1 %32
      • After removing the top cover of the LCD assembly, remove the LCD using the plastic opening tool.
      Pergunte ao FixBot
      Comentar
    3. Canon Pixma MP480 Data Port Replacement: passo 11, imagem 1 %32
      • Gently pull the ribbon cable to remove the LCD completely.
      Pergunte ao FixBot
      Comentar
    1. Canon Pixma MP480 Data Port Replacement, Buttons: passo 12, imagem 1 %32
      • Locate the buttons on the top of the printer.
      Pergunte ao FixBot
      Comentar
    2. Canon Pixma MP480 Data Port Replacement: passo 13, imagem 1 %32
      • Using the plastic opening tool, gently pry under the button cover to remove it from its fixture.
      Pergunte ao FixBot
      Comentar
    3. Canon Pixma MP480 Data Port Replacement: passo 14, imagem 1 %32 Canon Pixma MP480 Data Port Replacement: passo 14, imagem 2 %32
      • Remove the five 7.7 mm screws using a Phillips #1 screwdriver.
      Pergunte ao FixBot
      Comentar
    4. Canon Pixma MP480 Data Port Replacement: passo 15, imagem 1 %32 Canon Pixma MP480 Data Port Replacement: passo 15, imagem 2 %32
      • Using the plastic opening tool, gently pry around the cover behind the LCD screen to remove it from its fixture.
      Pergunte ao FixBot
      Comentar
    5. Canon Pixma MP480 Data Port Replacement: passo 16, imagem 1 %32 Canon Pixma MP480 Data Port Replacement: passo 16, imagem 2 %32
      • Remove the two 7.8 mm screws using a Phillips #1 screwdriver.
      Pergunte ao FixBot
      Comentar
    6. Canon Pixma MP480 Data Port Replacement: passo 17, imagem 1 %32
      • Gently pull the LCD screen up to remove it from its fixture.
      Pergunte ao FixBot
      Comentar
    7. Canon Pixma MP480 Data Port Replacement: passo 18, imagem 1 %32
      • Use the plastic opening tool to pry off the plastic button assembly.
      Pergunte ao FixBot
      Comentar
    8. Canon Pixma MP480 Data Port Replacement: passo 19, imagem 1 %32
      • Gently pull the plastic button assembly up to remove it.
      • The plastic button assembly has a ribbon cable connected on the bottom, so be careful pulling it.
      Pergunte ao FixBot
      Comentar
    9. Canon Pixma MP480 Data Port Replacement: passo 20, imagem 1 %32
      • Remove the ribbon cable connected to the backside of the plastic button assembly.
      Pergunte ao FixBot
      Comentar
    10. Canon Pixma MP480 Data Port Replacement: passo 21, imagem 1 %32 Canon Pixma MP480 Data Port Replacement: passo 21, imagem 2 %32
      • Remove the seven 8.7 mm screws using the Phillips #1 screwdriver.
      Pergunte ao FixBot
      Comentar
    11. Canon Pixma MP480 Data Port Replacement: passo 22, imagem 1 %32 Canon Pixma MP480 Data Port Replacement: passo 22, imagem 2 %32 Canon Pixma MP480 Data Port Replacement: passo 22, imagem 3 %32
      • Locate the spring that holds the PCB in place on the bottom left of the plastic button assembly.
      • Gently lift the spring and pull the board out of its plastic button assembly.
      Pergunte ao FixBot
      Comentar
    12. Canon Pixma MP480 Data Port Replacement: passo 23, imagem 1 %32
      • Remove the buttons from the plastic button assembly.
      Pergunte ao FixBot
      Comentar
    1. Canon Pixma MP480 Data Port Replacement, Data Port: passo 24, imagem 1 %32 Canon Pixma MP480 Data Port Replacement, Data Port: passo 24, imagem 2 %32
      • Remove the 7.5 mm screw using the Phillips #1 screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Canon Pixma MP480 Data Port Replacement: passo 25, imagem 1 %32 Canon Pixma MP480 Data Port Replacement: passo 25, imagem 2 %32
      • Remove the five 3.5 mm screws using the Phillips #1 screwdriver.
      Pergunte ao FixBot
      Comentar
    3. Canon Pixma MP480 Data Port Replacement: passo 26, imagem 1 %32
      • Remove the small plastic clip using the spudger.
      Pergunte ao FixBot
      Comentar
    4. Canon Pixma MP480 Data Port Replacement: passo 27, imagem 1 %32
      • Pull the plastic inserts out of the holes in the top and bottom.
      Pergunte ao FixBot
      Comentar
    5. Canon Pixma MP480 Data Port Replacement: passo 28, imagem 1 %32
      • Remove the board from the printer by pulling the board towards the back of the printer.
      • This requires effort and time as the board comes out slowly.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
Cal Poly, Team 19-41, Regan Winter 2013 Membro de Cal Poly, Team 19-41, Regan Winter 2013
CPSU-REGAN-W13S19G41
4 Membros
Autoria de 42 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 42
Ao todo: 2,755
