Ir para o conteúdo principal
Canon EOS 30 Battery Door Replacement
O que você precisa
    1. Canon EOS 30 Battery Door Replacement, Front Panel: passo 1, imagem 1 %32
      • Remove the two 4.8 mm black screws above the lens on the front of the camera.
      Pergunte ao FixBot
      Comentar
    2. Canon EOS 30 Battery Door Replacement: passo 2, imagem 1 %32
      • Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
      Pergunte ao FixBot
      Comentar
    3. Canon EOS 30 Battery Door Replacement: passo 3, imagem 1 %32
      • Remove the 4.8 mm black screw on the left side of the camera.
      Pergunte ao FixBot
      Comentar
    4. Canon EOS 30 Battery Door Replacement: passo 4, imagem 1 %32
      • Remove the front panel by lifting it away from the camera's body.
      Pergunte ao FixBot
      Comentar
    1. Canon EOS 30 Battery Door Replacement, Bottom Panel: passo 5, imagem 1 %32
      • Remove seven 4.25 mm black screws on the bottom panel.
      Pergunte ao FixBot
      Comentar
    2. Canon EOS 30 Battery Door Replacement: passo 6, imagem 1 %32
      • Remove the bottom panel.
      Pergunte ao FixBot
      Comentar
    1. Canon EOS 30 Battery Door Replacement, Side Panel With Remote Control Socket: passo 7, imagem 1 %32
      • Remove two 6.5 mm black screws from the panel.
      Pergunte ao FixBot
      Comentar
    2. Canon EOS 30 Battery Door Replacement: passo 8, imagem 1 %32
      • Remove the plastic remote control socket cap by pulling it straight out.
      Pergunte ao FixBot
      Comentar
    3. Canon EOS 30 Battery Door Replacement: passo 9, imagem 1 %32 Canon EOS 30 Battery Door Replacement: passo 9, imagem 2 %32
      • Slide the panel toward the bottom of the camera to remove.
      Pergunte ao FixBot
      Comentar
    4. Canon EOS 30 Battery Door Replacement: passo 10, imagem 1 %32
      • Remove the single 4.8 silver screw from the control socket.
      Pergunte ao FixBot
      Comentar
    5. Canon EOS 30 Battery Door Replacement: passo 11, imagem 1 %32 Canon EOS 30 Battery Door Replacement: passo 11, imagem 2 %32
      • The control socket is now secure by three wires.
      • Desolder connections to replace the remote control socket.
      Pergunte ao FixBot
      Comentar
    1. Canon EOS 30 Battery Door Replacement, Top Panel: passo 12, imagem 1 %32
      • Slide the outer eyepiece upward to remove it.
      Pergunte ao FixBot
      Comentar
    2. Canon EOS 30 Battery Door Replacement: passo 13, imagem 1 %32
      • Remove the two 4.75 mm black screws located on the top of the camera.
      Pergunte ao FixBot
      Comentar
    3. Canon EOS 30 Battery Door Replacement: passo 14, imagem 1 %32
      • Remove the four 4.3 mm black screws near the bottom corners of the eyepiece at the back of the camera.
      Pergunte ao FixBot
      Comentar
    4. Canon EOS 30 Battery Door Replacement: passo 15, imagem 1 %32 Canon EOS 30 Battery Door Replacement: passo 15, imagem 2 %32
      • Slowly separate the top panel from the camera by pushing it upward.
      • Separating the top panel too far or quickly can damage the ribbon cable and connecting wires that are still attached to the top panel of the camera.
      Pergunte ao FixBot
      Comentar
    1. Canon EOS 30 Battery Door Replacement, Grip: passo 16, imagem 1 %32
      • Remove the two 5.5 mm screws from front of camera.
      Pergunte ao FixBot
      Comentar
    2. Canon EOS 30 Battery Door Replacement: passo 17, imagem 1 %32
      • Remove grip panel.
      Pergunte ao FixBot
      Comentar
    1. Canon EOS 30 Battery Door Replacement, Battery Door: passo 18, imagem 1 %32
      • Remove one black screw from battery door on underside of grip.
      Pergunte ao FixBot
      Comentar
    2. Canon EOS 30 Battery Door Replacement: passo 19, imagem 1 %32
      • Remove battery door.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Jackie
Membro desde: 04/17/11
257 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 8-8, Regan Spring 2011 Membro de Cal Poly, Team 8-8, Regan Spring 2011
CPSU-REGAN-S11S8G8
5 Membros
Autoria de 44 guias
1Comentário do guia
I was able to complete this by going from step 9 to 15. Oddly, I only had one screw to remove in step 15 but the grip piece easily slid out without needing to remove the top of the camera.
Alan - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 21
Últimos 30 dias: 66
Ao todo: 5,142
