Ir para o conteúdo principal
CamPark BM20 Screen Replacement
O que você precisa
    1. CamPark BM20 Screen Replacement, Motherboard: passo 1, imagem 1 %32 CamPark BM20 Screen Replacement, Motherboard: passo 1, imagem 2 %32 CamPark BM20 Screen Replacement, Motherboard: passo 1, imagem 3 %32
      • Use your fingers to slide the battery cover off the back of the handheld device.
      • Disconnect the battery cable from the connector attached at the bottom of the device.
      • Remove the battery.
      Pergunte ao FixBot
      Comentar
    2. CamPark BM20 Screen Replacement: passo 2, imagem 1 %32 CamPark BM20 Screen Replacement: passo 2, imagem 2 %32
      • Use a Phillips #0 screwdriver to remove the three 12.7 mm screws from the lower back of the device.
      • Insert the tip of an iFixit opening tool between the front and back casing seams to release the clips securing the two halves.
      Pergunte ao FixBot
      Comentar
    3. CamPark BM20 Screen Replacement: passo 3, imagem 1 %32 CamPark BM20 Screen Replacement: passo 3, imagem 2 %32
      • Gently separate the top and bottom casing.
      • Don't pull the two halves apart as they are still connected by the speaker and antenna cables and you could damage the device.
      • Unplug the speaker cable from the socket on the motherboard.
      Pergunte ao FixBot
      Comentar
    4. CamPark BM20 Screen Replacement: passo 4, imagem 1 %32 CamPark BM20 Screen Replacement: passo 4, imagem 2 %32
      • Remove the four 6.35 mm screws on the motherboard with a Phillips #00 screwdriver.
      • Remove the motherboard from the front case.
      • The motherboard is still connected to the bottom casing by the antenna cable so be careful that you don't pull the cable and break it.
      Pergunte ao FixBot
      Comentar
    5. CamPark BM20 Screen Replacement: passo 5, imagem 1 %32 CamPark BM20 Screen Replacement: passo 5, imagem 2 %32 CamPark BM20 Screen Replacement: passo 5, imagem 3 %32
      • Use a soldering iron to desolder the antenna cable from the motherboard of the handheld device.
      • A soldering iron gets extremely hot and can easily burn skin or other surfaces. Always solder in a well-ventilated area.
      • Though the photo shows the board in the case, it is better to desolder the connections after the motherboard is removed.
      • The device’s screen is stacked directly above the motherboard, with both components layered tightly together.
      Pergunte ao FixBot
      Comentar
    1. CamPark BM20 Screen Replacement, Screen: passo 6, imagem 1 %32 CamPark BM20 Screen Replacement, Screen: passo 6, imagem 2 %32 CamPark BM20 Screen Replacement, Screen: passo 6, imagem 3 %32
      • Flip the screen forward to reveal the ZIF connector and yellow ribbon cable connecting the screen to the board.
      • Use a spudger or a clean fingernail to flip up the black locking flap under the yellow tape to unlock the connector.
      • Use tweezers or your fingers to gently pull the cable out of its socket.
      • Remove the screen.
      Pergunte ao FixBot
      Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 22
Ao todo: 211
