Ir para o conteúdo principal
CamPark BM20 Buttons Replacement
O que você precisa
  1. CamPark BM20 Buttons Replacement, Battery: passo 1, imagem 1 %32 CamPark BM20 Buttons Replacement, Battery: passo 1, imagem 2 %32 CamPark BM20 Buttons Replacement, Battery: passo 1, imagem 3 %32
    • Flip the handheld monitor so the back is facing you.
    • Use your fingers to slide the battery cover off to access the battery.
    Pergunte ao FixBot
    Comentar
  2. CamPark BM20 Buttons Replacement: passo 2, imagem 1 %32 CamPark BM20 Buttons Replacement: passo 2, imagem 2 %32
    • Use a spudger or your fingers to unplug the battery cable from the handheld device.
    • Remove the battery.
    Pergunte ao FixBot
    Comentar
  3. CamPark BM20 Buttons Replacement, Buttons: passo 3, imagem 1 %32 CamPark BM20 Buttons Replacement, Buttons: passo 3, imagem 2 %32 CamPark BM20 Buttons Replacement, Buttons: passo 3, imagem 3 %32
    • Use a Phillips #0 screwdriver to remove the three 12.7 mm screws from the lower back of the device.
    • Insert the tip of an iFixit opening tool between the front and back casing seams to release the clips securing the two halves.
    • Gently pry apart the handheld unit.
    Pergunte ao FixBot
    Comentar
  4. CamPark BM20 Buttons Replacement: passo 4, imagem 1 %32 CamPark BM20 Buttons Replacement: passo 4, imagem 2 %32 CamPark BM20 Buttons Replacement: passo 4, imagem 3 %32
    • Unplug the speaker cable from the socket on the motherboard.
    Pergunte ao FixBot
    Comentar
  5. CamPark BM20 Buttons Replacement: passo 5, imagem 1 %32
    • Using a Phillips #00 screwdriver, remove the four 6.35 mm screws from the corners of the motherboard.
    Pergunte ao FixBot
    Comentar
  6. CamPark BM20 Buttons Replacement: passo 6, imagem 1 %32 CamPark BM20 Buttons Replacement: passo 6, imagem 2 %32
    • Remove the motherboard from the front case and set it on the bottom case with the speaker.
    Pergunte ao FixBot
    Comentar
  7. CamPark BM20 Buttons Replacement: passo 7, imagem 1 %32 CamPark BM20 Buttons Replacement: passo 7, imagem 2 %32 CamPark BM20 Buttons Replacement: passo 7, imagem 3 %32
    • Remove the volume and directional buttons from the top cover.
    • The power and speaker buttons cannot be removed without breaking them off.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Subah Shabnam
Membro desde: 02/24/25
837 Reputação
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 26
Ao todo: 212
