Ir para o conteúdo principal
CM Storm QuickFire Rapid O-ring: Large Keycap Installation
O que você precisa
    1. CM Storm QuickFire Rapid O-ring: Large Keycap Installation, O-ring: Large Keycap: passo 1, imagem 1 %32 CM Storm QuickFire Rapid O-ring: Large Keycap Installation, O-ring: Large Keycap: passo 1, imagem 2 %32 CM Storm QuickFire Rapid O-ring: Large Keycap Installation, O-ring: Large Keycap: passo 1, imagem 3 %32
      Pergunte ao FixBot
      Comentar
    2. CM Storm QuickFire Rapid O-ring: Large Keycap Installation: passo 2, imagem 1 %32
      • Pull the large keycap upward with your fingers until the cap separates from the plastic rings underneath the cap. If the metal bar beneath the cap comes loose during removal, snap it back in place.
      Pergunte ao FixBot
      Comentar
    3. CM Storm QuickFire Rapid O-ring: Large Keycap Installation: passo 3, imagem 1 %32 CM Storm QuickFire Rapid O-ring: Large Keycap Installation: passo 3, imagem 2 %32 CM Storm QuickFire Rapid O-ring: Large Keycap Installation: passo 3, imagem 3 %32
      • Remove the plastic rings from the keycap.
      Pergunte ao FixBot
      Comentar
    4. CM Storm QuickFire Rapid O-ring: Large Keycap Installation: passo 4, imagem 1 %32 CM Storm QuickFire Rapid O-ring: Large Keycap Installation: passo 4, imagem 2 %32
      • Place the O-rings around the nubs underneath the keycap at each circled locations.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team 6-23, Maness Fall 2014 Membro de Cal Poly, Team 6-23, Maness Fall 2014
CPSU-MANESS-F14S6G23
4 Membros
Autoria de 42 guias
1Comentário do guia
Best choice if you want all the “click” but none of the “clack” on your mechanical keyboard
Cherry Mx Black Rubber O-rings (125 pcs -EPDM – 40A) €3,98
Cherry Mx Black Rubber O-rings (90 pcs -EPDM – 40A) €3,48
[NL] O-rings Webstore http://tigri.bigcartel.com
Specs
Material: EPDM Industrial Grade Rubber
Color: Black
Hardness: 40A
Thickness: 1,50 mm (0.059 in)
Packaging: 125 pcs/bag or 90 pcs/bag
tigriorings - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 41
Ao todo: 2,380
