Ir para o conteúdo principal
Bose SoundDock Portable v2 Docking System Board Replacement
O que você precisa
  1. Bose SoundDock Portable v2 Docking System Board Replacement, Docking System Board: passo 1, imagem 1 %32
    • Lay the speaker flat on its back, balancing on the battery.
    • Remove the four rubber disks that cover the screws on the bottom of the speaker.
    • Follow the battery replacement guide to remove the battery
    Pergunte ao FixBot
    Comentar
  2. Bose SoundDock Portable v2 Docking System Board Replacement: passo 2, imagem 1 %32
    • Now, remove the four 16mm #2 screws on the bottom of the speaker. This will allow the bottom plate to be removed.
    • It may be easier to the remove the battery so that the speaker will lay flat on the table.
    Pergunte ao FixBot
    Comentar
  3. Bose SoundDock Portable v2 Docking System Board Replacement: passo 3, imagem 1 %32
    • Carefully remove the bottom panel of the speaker.
    • You may have to rock the panel back and forth to get it to slide off the plastic pegs.
    Pergunte ao FixBot
    Comentar
  4. Bose SoundDock Portable v2 Docking System Board Replacement: passo 4, imagem 1 %32
    • Once the panel is removed you will see a ribbon connecting the dock to the speaker. Be careful to orient the speaker so that you can work on the dock connector without pulling on the ribbon!
    Pergunte ao FixBot
    Comentar
  5. Bose SoundDock Portable v2 Docking System Board Replacement: passo 5, imagem 1 %32 Bose SoundDock Portable v2 Docking System Board Replacement: passo 5, imagem 2 %32
    • Use a T15 Torx screwdriver to remove the dock from the base. Be careful not to damage the ribbon during this step.
    • There is a torsion spring under the dock. When removed, this spring has a tendency to fly out. To avoid this, loosen the dock until it is able to move freely. Rotate it so that there is no tension in the spring. Then, you are free to undo the screw completely.
    Pergunte ao FixBot
    Comentar
  6. Bose SoundDock Portable v2 Docking System Board Replacement: passo 6, imagem 1 %32 Bose SoundDock Portable v2 Docking System Board Replacement: passo 6, imagem 2 %32
    • Remove the three 6mm T8 torques screws that hold the dock connector together and pull the top and bottom pieces apart.
    • There are some small parts that may fall out when the plastic pieces are separated. To minimize this, lay the piece with the dock connector facing down.
    Pergunte ao FixBot
    Comentar
  7. Bose SoundDock Portable v2 Docking System Board Replacement: passo 7, imagem 1 %32 Bose SoundDock Portable v2 Docking System Board Replacement: passo 7, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Once the pieces are separated, the dock connector can be lifted out of the slot.
    • Using tweezers or your fingers, unplug the two ribbon connectors from the board.
    Pergunte ao FixBot
    Comentar
Conclusão
6 outras pessoas executaram este guia.
Evan Low
Membro desde: 04/14/15
584 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 4-1, Maness Spring 2015 Membro de Cal Poly, Team 4-1, Maness Spring 2015
CPSU-MANESS-S15S4G1
4 Membros
Autoria de 5 guias
2Comentários do guia
How can I tell if it is my IPOD or the Bose system that needs to be repaired?
Ron Adams - Responder Compartilhar
Where can I by this piece? I have to replace that piece.
PHelmut - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 20
Últimos 30 dias: 90
Ao todo: 23,163
