Ir para o conteúdo principal
Bose SoundDock Portable v2 Battery Replacement
O que você precisa
  1. Bose SoundDock Portable v2 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Using your thumbnail or a coin, push in the slotted knob on the battery and turn it counterclockwise to unlock the battery.
  2. Bose SoundDock Portable v2 Battery Replacement: passo 2, imagem 1 %32
    • Carefully pull the battery away from the back of the system.
  3. Bose SoundDock Portable v2 Battery Replacement: passo 3, imagem 1 %32
    • On the new battery, make sure the slot in the knob on the battery is in a horizontal position.
    • Insert the battery into the multi-pin connector.
  4. Bose SoundDock Portable v2 Battery Replacement: passo 4, imagem 1 %32
    • Push in the slotted knob and turn it clockwise until the slot is vertical. This locks the battery in place.
  5. Bose SoundDock Portable v2 Battery Replacement: passo 5, imagem 1 %32
    • Connect the power supply and charge the battery.
Conclusão
4 outras pessoas executaram este guia.
Evan Low
Membro desde: 04/14/15
584 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 4-1, Maness Spring 2015 Membro de Cal Poly, Team 4-1, Maness Spring 2015
CPSU-MANESS-S15S4G1
4 Membros
Autoria de 5 guias
8Comentários do guia
I think it would be cool to show a Teardown of the Bose SoundDock Portable v2 Battery.
Joseph Gorse - Responder Compartilhar
I agree. These batteries seem prone to failure and I’d like to replace the cells or whatever it is that is the failure point.
adam-marsh - Compartilhar
Thanks for your easy and concise help.
Stuart Friedman - Responder Compartilhar
Battery is repairable.
There are 4 screws under plastic plugs under sticker. They are one way heads :( use force or a drill.
Locking thingy removal - push the cross pin through - pliers or vise grips to grab and pull out completely. Keep an eye on where spring went.
There may be a bit of glue or tape holding cover too.
4 x 18650 Li-ion cells in 2 banks at each side of the charging board which is held down by 5 screws. Some adhesive was used to hold the cells to the back.
Use meter to check. Mine had one cell at 0V so that was the culprit.
Remove any bad cells by cutting the glue about the temp sensors to carefully get them out of the way. Then cut the cell tags - careful not to short anything as there is charge about. I found it faster to cut tags but you could unglue all cells and lift the board and do that way. My replacement cell came from a Dell laptop pack. Glue the new battery in place (I used automotive trim tape as it was handy) and solder the new cell. Reglue temp sensors.
Reassemble with some new screws.
Affeke Nommu - Responder Compartilhar
Hi. How do you push the cross pin through? I can’t
Enrique Francis - Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 30
Últimos 30 dias: 108
Ao todo: 27,796
