Ir para o conteúdo principal
Blu Grand M2 Display Replacement
O que você precisa
  1. Blu Grand M2 Display Replacement, Display: passo 1, imagem 1 %32 Blu Grand M2 Display Replacement, Display: passo 1, imagem 2 %32
    • Before beginning the guide, be sure that this replacement guide addresses your specific problem.
    • Locate the two Torx screws at the bottom of the phone and remove them.
    Pergunte ao FixBot
    Comentar
  2. Blu Grand M2 Display Replacement: passo 2, imagem 1 %32
    • Use the pry tool to wedge between the phone's frame and the back plate.
    • Carefully remove the back plate using the suction tool.
    • Be careful not to damage the phone display and/or the inside components while using the pry tool and the suction tool.
    Pergunte ao FixBot
    Comentar
  3. Blu Grand M2 Display Replacement: passo 3, imagem 1 %32 Blu Grand M2 Display Replacement: passo 3, imagem 2 %32 Blu Grand M2 Display Replacement: passo 3, imagem 3 %32
    • Once the back panel is removed, locate the connector of the display shown in figure 1 on the motherboard side.
    • There will be an orange sticker above the previously mentioned connector. You can gently lift the connector up to release it.
    • Disconnect the two remaining connectors shown in figure 3.
    Pergunte ao FixBot
    Comentar
  4. Blu Grand M2 Display Replacement: passo 4, imagem 1 %32 Blu Grand M2 Display Replacement: passo 4, imagem 2 %32
    • After removing the connectors, locate the six Phillips screws on the motherboard side and remove them.
    • After removing the six Phillips screws, remove the motherboard piece.
    Pergunte ao FixBot
    Comentar
  5. Blu Grand M2 Display Replacement: passo 5, imagem 1 %32
    • Once you have removed the motherboard piece, flip the phone so the screen is facing up and begin using the iOpener.
    • Heat up the iOpener from the iFixit kit for 30 seconds in a microwave and apply it on top of the screen to loosen the phone's adhesive.
    • The iOpener can be hot once it is microwaved. Make sure to wear gloves and other safety equipment to prevent any burns.
    Pergunte ao FixBot
    Comentar
  6. Blu Grand M2 Display Replacement: passo 6, imagem 1 %32 Blu Grand M2 Display Replacement: passo 6, imagem 2 %32 Blu Grand M2 Display Replacement: passo 6, imagem 3 %32
    • Using the suction tool, slowly pull out the display screen shown in figure 1.
    • Use the pry tool to completely detach the display screen from the phone.
    • When the display is removed, attach your new screen.
    • After applying the new screen, use the steps in reverse order to reassemble the phone.
    Pergunte ao FixBot
    Comentar
Conclusão
Christopher
Membro desde: 09/10/18
192 Reputação
Autoria de 1 guia
Equipe
Gateway, Team S1-G3, Luster Fall 2018 Membro de Gateway, Team S1-G3, Luster Fall 2018
GCC-LUSTER-F18S1G3
4 Membros
Autoria de 8 guias
1Comentário do guia
What type of torx screwdriver did you use?
npyles86 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 7
Últimos 30 dias: 34
Ao todo: 2,207
