Ir para o conteúdo principal
Blink Outdoor 4 Camera Replacement
O que você precisa
    1. Blink Outdoor 4 Camera Replacement, Blink Outdoor 4 Camera: passo 1, imagem 1 %32 Blink Outdoor 4 Camera Replacement, Blink Outdoor 4 Camera: passo 1, imagem 2 %32 Blink Outdoor 4 Camera Replacement, Blink Outdoor 4 Camera: passo 1, imagem 3 %32
      • Remove the mounting bracket from the device if necessary.
      • Flip the camera upside down.
      • The word 'Blink' should be at the top.
      • Insert the swivel multi-tool that was included in the Blink Outdoor 4 box into the small notch located inside the silver circle in the center of the device.
      • Twist to the left until you hear a click.
      Pergunte ao FixBot
      Comentar
    2. Blink Outdoor 4 Camera Replacement: passo 2, imagem 1 %32 Blink Outdoor 4 Camera Replacement: passo 2, imagem 2 %32
      • Use a spudger to gently pry the back casing off the device.
      • Remove the two batteries and set them aside.
      • When reattaching the back casing, turn the swivel tool to the right.
      Pergunte ao FixBot
      Comentar
    3. Blink Outdoor 4 Camera Replacement: passo 3, imagem 1 %32 Blink Outdoor 4 Camera Replacement: passo 3, imagem 2 %32
      • Remove all four screws near the battery compartments using a Phillips #1 screwdriver.
      • Make sure to keep track of the screws for reassembly.
      Pergunte ao FixBot
      Comentar
    4. Blink Outdoor 4 Camera Replacement: passo 4, imagem 1 %32 Blink Outdoor 4 Camera Replacement: passo 4, imagem 2 %32 Blink Outdoor 4 Camera Replacement: passo 4, imagem 3 %32
      • Turn the device on its side.
      • Use a plastic spudger to gently pry off the front cover of the device.
      Pergunte ao FixBot
      Comentar
    5. Blink Outdoor 4 Camera Replacement: passo 5, imagem 1 %32 Blink Outdoor 4 Camera Replacement: passo 5, imagem 2 %32 Blink Outdoor 4 Camera Replacement: passo 5, imagem 3 %32
      • Use a Phillips #00 screwdriver to remove the two small black screws in the upper right corner of the board.
      • Make sure to keep the screws for reassembly.
      • Gently lift the motherboard out of the device by its edges.
      • Do not pull on the board because it's attached to some cables from underneath and it could damage the device.
      Pergunte ao FixBot
      Comentar
    6. Blink Outdoor 4 Camera Replacement: passo 6, imagem 1 %32 Blink Outdoor 4 Camera Replacement: passo 6, imagem 2 %32 Blink Outdoor 4 Camera Replacement: passo 6, imagem 3 %32
      • Squeeze the edges of the white camera connector and slide it out of the socket on the motherboard.
      • If that doesn't work, use the point of a spudger to push on alternating sides of the white camera connector to "walk" it out of its socket.
      • It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
      • Remove the camera from the device.
      Pergunte ao FixBot
      Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Delaney Hye
Membro desde: 02/05/26
749 Reputação
Autoria de 5 guias
Equipe
Texas Tech, Team 11-5, Weston Spring 2026 Membro de Texas Tech, Team 11-5, Weston Spring 2026
TTU-WESTON-S26S11G5
5 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 21
Últimos 30 dias: 112
Ao todo: 341
