Ir para o conteúdo principal
Blink Outdoor 4 Battery Replacement
O que você precisa
    1. Blink Outdoor 4 Battery Replacement, Blink Outdoor 4 Battery: passo 1, imagem 1 %32
      • If the mounting bracket is attached, remove it from the back of the device.
      • Flip the camera so the bottom is facing up.
      • The word 'Blink' should be at the top.
      Pergunte ao FixBot
      Comentar
    2. Blink Outdoor 4 Battery Replacement: passo 2, imagem 1 %32 Blink Outdoor 4 Battery Replacement: passo 2, imagem 2 %32 Blink Outdoor 4 Battery Replacement: passo 2, imagem 3 %32
      • Insert the swivel multi-tool (included in the Blink Outdoor 4 box) into the small notch located in the silver circle in the center of the device.
      • Twist to the left until you hear a click.
      Pergunte ao FixBot
      Comentar
    3. Blink Outdoor 4 Battery Replacement: passo 3, imagem 1 %32 Blink Outdoor 4 Battery Replacement: passo 3, imagem 2 %32
      • Use a spudger to gently pry the back casing off the device.
      • Remove the two old batteries.
      • Insert two new AA 1.5V Lithium batteries in the assigned compartments.
      • Ensure that the new batteries are aligned with the correct polarity.
      • When reattaching the back casing, turn the swivel tool to the right.
      Pergunte ao FixBot
      Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Delaney Hye
Membro desde: 02/05/26
749 Reputação
Autoria de 5 guias
Equipe
Texas Tech, Team 11-5, Weston Spring 2026 Membro de Texas Tech, Team 11-5, Weston Spring 2026
TTU-WESTON-S26S11G5
5 Membros
Autoria de 9 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 77
Ao todo: 291
