Ir para o conteúdo principal
Bissell CrossWave Cordless Max 2554A Motor Replacement
O que você precisa
  1. Bissell CrossWave Cordless Max 2554A Motor Replacement, Battery Assembly: passo 1, imagem 1 %32 Bissell CrossWave Cordless Max 2554A Motor Replacement, Battery Assembly: passo 1, imagem 2 %32
    • Remove the four 16 mm Phillips #2 screws at the back of the vacuum and below the clean water tank.
  2. Bissell CrossWave Cordless Max 2554A Motor Replacement: passo 2, imagem 1 %32 Bissell CrossWave Cordless Max 2554A Motor Replacement: passo 2, imagem 2 %32
    • Pull the battery assembly away from the main body.
    • There are still wires connecting the battery assembly to the main body. Do not use force to completely separate the two objects.
  3. Bissell CrossWave Cordless Max 2554A Motor Replacement: passo 3, imagem 1 %32 Bissell CrossWave Cordless Max 2554A Motor Replacement: passo 3, imagem 2 %32
    • Detach the wires holding the battery assembly to the main body by pressing down on the clip holding the connector together.
  4. Bissell CrossWave Cordless Max 2554A Motor Replacement, Motor: passo 4, imagem 1 %32 Bissell CrossWave Cordless Max 2554A Motor Replacement, Motor: passo 4, imagem 2 %32 Bissell CrossWave Cordless Max 2554A Motor Replacement, Motor: passo 4, imagem 3 %32
    • Remove the clean and dirty water tanks.
    • Removing the tanks gives access to all of the screw holes required to disassemble the vacuum housing.
  5. Bissell CrossWave Cordless Max 2554A Motor Replacement: passo 5, imagem 1 %32 Bissell CrossWave Cordless Max 2554A Motor Replacement: passo 5, imagem 2 %32 Bissell CrossWave Cordless Max 2554A Motor Replacement: passo 5, imagem 3 %32
    • Remove the two 13.8 mm Phillips #1 screws holding the carrying handle to the main body.
  6. Bissell CrossWave Cordless Max 2554A Motor Replacement: passo 6, imagem 1 %32 Bissell CrossWave Cordless Max 2554A Motor Replacement: passo 6, imagem 2 %32 Bissell CrossWave Cordless Max 2554A Motor Replacement: passo 6, imagem 3 %32
    • Remove the six 14 mm Phillips #1 screws that are located where the clean water tank once was.
    • Remove the two 14 mm silver screws located underneath the battery using a Phillips #1 screwdriver.
  7. Bissell CrossWave Cordless Max 2554A Motor Replacement: passo 7, imagem 1 %32 Bissell CrossWave Cordless Max 2554A Motor Replacement: passo 7, imagem 2 %32
    • Flip the device over and remove the three 12.3 mm Phillips #1 screws.
    • Remove two 15 mm Phillips #1 screws.
  8. Bissell CrossWave Cordless Max 2554A Motor Replacement: passo 8, imagem 1 %32 Bissell CrossWave Cordless Max 2554A Motor Replacement: passo 8, imagem 2 %32
    • Remove the two front pieces of plastic from the main body of the vacuum.
    • There are many wires still connected from the main body to these front panels. Use caution when separating the plastic as to not break the wiring.
  9. Bissell CrossWave Cordless Max 2554A Motor Replacement: passo 9, imagem 1 %32 Bissell CrossWave Cordless Max 2554A Motor Replacement: passo 9, imagem 2 %32
    • The panel can be flipped over to reveal the motor when separated from the main body.
  10. Bissell CrossWave Cordless Max 2554A Motor Replacement: passo 10, imagem 1 %32 Bissell CrossWave Cordless Max 2554A Motor Replacement: passo 10, imagem 2 %32
    • Remove the four 14 mm Phillips #1 screws that hold the motor to the front panel of the vacuum.
  11. Bissell CrossWave Cordless Max 2554A Motor Replacement: passo 11, imagem 1 %32 Bissell CrossWave Cordless Max 2554A Motor Replacement: passo 11, imagem 2 %32 Bissell CrossWave Cordless Max 2554A Motor Replacement: passo 11, imagem 3 %32
    • The two wire connections can be desoldered to completely free the motor from the rest of the vacuum.
    • Be extremely careful while soldering or desoldering these connections, as the soldering iron can get very hot.
Conclusão
Erin Rodgers
Membro desde: 09/30/21
337 Reputação
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 41
Duração total: 121
