Introdução
The motor in the Bissell CrossWave Cordless Max (model 2554A) is connected to the display through wires. If the motor is not working correctly, the vacuum is inoperable. This can stem from various issues with the battery and the motherboard. This guide has troubleshooting information.
Without the wires being soldered to the motor, the vacuum will not have a motor. The last step features soldering the connecting for the motor. For good practice, this guide has information on soldering.
O que você precisa
Remove the four 16 mm Phillips #2 screws at the back of the vacuum and below the clean water tank.
