Ir para o conteúdo principal
Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement
O que você precisa
  1. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement, Throttle Cable: passo 1, imagem 1 %32 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement, Throttle Cable: passo 1, imagem 2 %32 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement, Throttle Cable: passo 1, imagem 3 %32
    • Cut and remove any zip ties securing the throttle cable.
  2. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: passo 2, imagem 1 %32 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: passo 2, imagem 2 %32
    • Use a Phillips #2 driver to remove the screw securing the lower end of the throttle cable.
  3. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: passo 3, imagem 1 %32 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: passo 3, imagem 2 %32
    • Remove the bracket securing the lower end of the throttle cable.
  4. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: passo 4, imagem 1 %32 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: passo 4, imagem 2 %32 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: passo 4, imagem 3 %32
    • Rotate the lower end of the throttle cable to detach it from the throttle.
  5. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: passo 5, imagem 1 %32 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: passo 5, imagem 2 %32 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: passo 5, imagem 3 %32
    • When reinstalling the throttle control cable, check to make sure that the throttle control moves the throttle through its full range of motion.
    • If necessary, loosen the screw securing the lower end of the throttle cable and adjust the position of the cable. Re-tighten the screw and check to make sure that the throttle moves through its full range of motion.
  6. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: passo 6, imagem 1 %32 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: passo 6, imagem 2 %32
    • Use a 7/16" wrench or deep socket to remove the cap from the throttle control.
  7. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: passo 7, imagem 1 %32 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: passo 7, imagem 2 %32
    • Advance the throttle control to expose the gear rack containing the upper end of the throttle cable.
  8. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: passo 8, imagem 1 %32 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: passo 8, imagem 2 %32 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: passo 8, imagem 3 %32
    • Separate the gear rack from the upper end of the throttle cable.
    • Lift and remove the gear rack from the throttle control.
    • If the gear rack doesn't fully detach, advance the throttle control lever a little farther.
    • Lubricate the gear rack with a bit of lithium grease during reassembly.
  9. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: passo 9, imagem 1 %32 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: passo 9, imagem 2 %32 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: passo 9, imagem 3 %32
    • Use a 1/2" wrench to unscrew the upper end of the throttle cable from the throttle control.
    • Slide the throttle cable down out of the bottom of the throttle control, and remove the cable.
  10. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement, Throttle Control: passo 10, imagem 1 %32 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement, Throttle Control: passo 10, imagem 2 %32
    • Use a Phillips #2 driver to remove the two screws securing the throttle control.
    • While removing the screws, use a 3/8" wrench to counter-hold the lock nuts and prevent them from rotating.
  11. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: passo 11, imagem 1 %32 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: passo 11, imagem 2 %32
    • Remove the throttle control.
Conclusão
4 outras pessoas executaram este guia.
Jeff Suovanen
Membro desde: 08/06/13
440.068 Reputação
Autoria de 259 guias
Equipe
iFixit Membro de iFixit
Staff
118 Membros
Autoria de 19.631 guias
1Comentário do guia
the part # is incorrect, it appears that it is 440014 not 440013
JACOB - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 23
Ao todo: 1,137
