Ir para o conteúdo principal
Beats Studio 2 Wireless Speaker Replacement
O que você precisa
  1. Beats Studio 2 Wireless Speaker Replacement, Ear Cushion: passo 1, imagem 1 %32 Beats Studio 2 Wireless Speaker Replacement, Ear Cushion: passo 1, imagem 2 %32
    • Insert a spudger between the plastic part of the left headphone and the ear cushion.
    • Work the spudger around the periphery of the base of the cushion and gently pry it off the head phone.
  2. Beats Studio 2 Wireless Speaker Replacement: passo 2, imagem 1 %32 Beats Studio 2 Wireless Speaker Replacement: passo 2, imagem 2 %32 Beats Studio 2 Wireless Speaker Replacement: passo 2, imagem 3 %32
    • Pull the rest of the cushion away from the adhesive with your hands.
  3. Beats Studio 2 Wireless Speaker Replacement, Speaker: passo 3, imagem 1 %32 Beats Studio 2 Wireless Speaker Replacement, Speaker: passo 3, imagem 2 %32
    • Using the Phillips #00 screwdriver, remove the screws holding the speaker in place.
    • If the speaker is on the side with the charging port be sure to keep the two screws holding the charging port separate.
  4. Beats Studio 2 Wireless Speaker Replacement: passo 4, imagem 1 %32
    • Gently separate the speaker from the headphones.
    • Don't pull or yank the speaker from the headphones. They are connected together by wires that might be damaged.
  5. Beats Studio 2 Wireless Speaker Replacement: passo 5, imagem 1 %32 Beats Studio 2 Wireless Speaker Replacement: passo 5, imagem 2 %32
    • Gently pull the wire with rubber connectors off of the speaker.
  6. Beats Studio 2 Wireless Speaker Replacement: passo 6, imagem 1 %32
    • Use a soldering iron to desolder the two connections.
    • For details on how to solder and desolder, refer to the How to Solder and Desolder Connections guide.
    • A soldering iron can produce very high temperatures, and can burn skin. Use with caution.
    • Note the position of the speaker in its housing, then carefully remove the faulty speaker.
Conclusão
After soldering the new speaker, reassemble your device by following the steps in reverse order.
3 outras pessoas executaram este guia.
Mike Rosiello
Membro desde: 03/20/23
313 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 5-3, Ramos Spring 2023 Membro de UMass Dartmouth, Team 5-3, Ramos Spring 2023
UMASSD-RAMOS-S23S5G3
Membros da 3
Autoria de 4 guias
Um comentário
I didn't need to replace a speaker but just touch up the solder joints, this was a great guide! Thank you!
William Pryor - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 26
Duração total: 365
