Ir para o conteúdo principal
BLU Dash JR D140 Microphone Replacement
O que você precisa
  1. BLU Dash JR D140 Microphone Replacement, Battery: passo 1, imagem 1 %32
    • Turn off the phone first. Press the power button continuously for 2-3 seconds to shut down the phone.
    • Using a plastic opening tool, pry open the back cover from the slit on the bottom right corner of the phone.
  2. BLU Dash JR D140 Microphone Replacement: passo 2, imagem 1 %32
    • Using a plastic opening tool or finger, pull out the battery.
  3. BLU Dash JR D140 Microphone Replacement, Microphone: passo 3, imagem 1 %32
    • Remove the four 4.0mm Phillips #1 screws.
  4. BLU Dash JR D140 Microphone Replacement: passo 4, imagem 1 %32 BLU Dash JR D140 Microphone Replacement: passo 4, imagem 2 %32
    • Starting from a corner, separate the panel from the frame using the plastic opening tool.
    • The volume button will pop out.
  5. BLU Dash JR D140 Microphone Replacement: passo 5, imagem 1 %32
    • Unscrew the 3.6mm Phillips #0 screw from the motherboard.
  6. BLU Dash JR D140 Microphone Replacement: passo 6, imagem 1 %32
    • Using a spudger, lift the black ZIF connector at the top left corner of the phone.
  7. BLU Dash JR D140 Microphone Replacement: passo 7, imagem 1 %32
    • Pull the ribbon cable out of the ZIF connector.
  8. BLU Dash JR D140 Microphone Replacement: passo 8, imagem 1 %32
    • When the ribbon cable is removed from the ZIF connector, peel off the power sticky button using a plastic opening tool.
  9. BLU Dash JR D140 Microphone Replacement: passo 9, imagem 1 %32
    • Peel off the volume sticky button.
  10. BLU Dash JR D140 Microphone Replacement: passo 10, imagem 1 %32
    • Separate the screen cover from the motherboard using the plastic opening tool.
    • Make sure that the LCD screen stays attached to the motherboard while doing this.
  11. BLU Dash JR D140 Microphone Replacement: passo 11, imagem 1 %32 BLU Dash JR D140 Microphone Replacement: passo 11, imagem 2 %32 BLU Dash JR D140 Microphone Replacement: passo 11, imagem 3 %32
    • The microphone is at the bottom left corner of the phone.
    • Lift the microphone very carefully. Unsolder the two lower wires (one red wire and one black wire).
    • If you don't feel comfortable with this step I recommend looking at Ifixit's solder guide here.
    • Solder the new microphone in the same spot. The black wire will go in the left spot and the red wire in the right spot.
Conclusão
Equipe
UW Tacoma, Team 1-4, Liner SU 2015 Membro de UW Tacoma, Team 1-4, Liner SU 2015
UWT-LINER-SU15S1G4
Membros da 4
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 16
Duração total: 540
