Ir para o conteúdo principal
Azpen A720 Speaker Replacement
O que você precisa
    1. Azpen A720 Speaker Replacement, Back Cover: passo 1, imagem 1 %32 Azpen A720 Speaker Replacement, Back Cover: passo 1, imagem 2 %32
      • Use a Phillips #00 screwdriver to remove the two 4mm screws found on the top edge of the tablet near the power button.
      Pergunte ao FixBot
      Comentar
    2. Azpen A720 Speaker Replacement: passo 2, imagem 1 %32 Azpen A720 Speaker Replacement: passo 2, imagem 2 %32 Azpen A720 Speaker Replacement: passo 2, imagem 3 %32
      • Use the plastic opening tool to pry the white back from the silver frame. Start near the micro SD slot.
      • Slide the plastic opening tool around the perimeter of the casing until the back is disconnected.
      Pergunte ao FixBot
      Comentar
    3. Azpen A720 Speaker Replacement: passo 3, imagem 1 %32
      • Remove the rear casing.
      Pergunte ao FixBot
      Comentar
    1. Azpen A720 Speaker Replacement, Speaker: passo 4, imagem 1 %32
      • The speaker is a black oval located in the corner next to the battery.
      Pergunte ao FixBot
      Comentar
    2. Azpen A720 Speaker Replacement: passo 5, imagem 1 %32
      • Use a soldering iron to desolder the connections between the black and red speaker wires and the motherboard.
      • Remember which lead the black and red wires connect to on the motherboard.
      • Caution: The soldering iron gets very hot; be careful not to touch the tip and burn yourself. To learn to solder, click here.
      Pergunte ao FixBot
      Comentar
    3. Azpen A720 Speaker Replacement: passo 6, imagem 1 %32
      • Remove the speaker from the tablet.
      Pergunte ao FixBot
      Comentar
Conclusão
Anna
Membro desde: 03/17/15
353 Reputação
Autoria de 3 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 19
Ao todo: 536
