Ir para o conteúdo principal
Auking M8-F PCB Button Panel Replacement
O que você precisa
  1. Auking M8-F PCB Button Panel Replacement, PCB Button Panel: passo 1, imagem 1 %32 Auking M8-F PCB Button Panel Replacement, PCB Button Panel: passo 1, imagem 2 %32
    • Make sure that the device is unplugged from any power source before attempting any repairs.
    • Flip the projector on its opposite side.
    • Remove all six of the 11 mm screws using a Phillips #1 screwdriver.
    • Remove the two 14 mm screws using a Phillips #1 screwdriver.
    Pergunte ao FixBot
    Comentar
  2. Auking M8-F PCB Button Panel Replacement: passo 2, imagem 1 %32 Auking M8-F PCB Button Panel Replacement: passo 2, imagem 2 %32
    • Carefully prop open the top of the projector.
    • Disconnect the cable attached to the top lid.
    • Remove the top lid.
    Pergunte ao FixBot
    Comentar
  3. Auking M8-F PCB Button Panel Replacement: passo 3, imagem 1 %32 Auking M8-F PCB Button Panel Replacement: passo 3, imagem 2 %32
    • Remove the wire cord attached to the top panel to separate both the top panel and the wire cord.
    Pergunte ao FixBot
    Comentar
  4. Auking M8-F PCB Button Panel Replacement: passo 4, imagem 1 %32 Auking M8-F PCB Button Panel Replacement: passo 4, imagem 2 %32 Auking M8-F PCB Button Panel Replacement: passo 4, imagem 3 %32
    • Remove six of the 5 mm screws using a Phillips #00 screwdriver to detach the power panel.
    • Remove the power panel.
    Pergunte ao FixBot
    Comentar
Conclusão
Aubrey Haynes
Membro desde: 09/13/23
286 Reputação
Autoria de 3 guias
1Comentário do guia
I have a problem not covered here.
When I power up, only a red light is lit. Any ideas?
sasquachnw@duck.com
sasquachnw - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 24
Ao todo: 312
