Ir para o conteúdo principal
Asus X553MA-BPD07051 RAM Replacement
O que você precisa
  1. Asus X553MA-BPD07051 RAM Replacement, Battery: passo 1, imagem 1 %32 Asus X553MA-BPD07051 RAM Replacement, Battery: passo 1, imagem 2 %32
    • Use a Phillips #0 screwdriver (PH0 bit) to remove the four 5.0 mm screws that are securing the bottom of the laptop.
    • Use a Phillips #0 screwdriver (PH0 bit) to remove the six 11.0 mm screws that are securing the bottom of the laptop.
    Pergunte ao FixBot
    Comentar
  2. Asus X553MA-BPD07051 RAM Replacement: passo 2, imagem 1 %32
    • Lift the edges of the keyboard using the plastic iFixit opening tool and raise the keyboard slightly to see the inside of the laptop.
    • Do not lift the keyboard too high as the keyboard is connected to the motherboard by two ribbon connectors that must be detached.
    Pergunte ao FixBot
    Comentar
  3. Asus X553MA-BPD07051 RAM Replacement: passo 3, imagem 1 %32 Asus X553MA-BPD07051 RAM Replacement: passo 3, imagem 2 %32
    • Lift back the clip on the ribbon tape, and pull the tape out in order to remove the keyboard from the laptop.
    • Remove both pieces of the ribbon tape connecting the keyboard to the motherboard.
    Pergunte ao FixBot
    Comentar
  4. Asus X553MA-BPD07051 RAM Replacement: passo 4, imagem 1 %32
    • Remove the bundled cable connector attaching the battery to the motherboard with the plastic iFixit opening tool.
    • Make sure that you do not remove the entire connector by applying too much force. Only the white plastic connector should be removed from the metal part on the motherboard. Lift white part upwards to remove.
    Pergunte ao FixBot
    Comentar
  5. Asus X553MA-BPD07051 RAM Replacement: passo 5, imagem 1 %32 Asus X553MA-BPD07051 RAM Replacement: passo 5, imagem 2 %32
    • Use Phillips #0 screwdriver (PH0 bit) to remove the four 6.0 mm screws attaching the battery to the laptop.
    Pergunte ao FixBot
    Comentar
  6. Asus X553MA-BPD07051 RAM Replacement: passo 6, imagem 1 %32 Asus X553MA-BPD07051 RAM Replacement: passo 6, imagem 2 %32
    • Lift the battery up and remove it completely from the laptop.
    Pergunte ao FixBot
    Comentar
  7. Asus X553MA-BPD07051 RAM Replacement, Hard Drive: passo 7, imagem 1 %32 Asus X553MA-BPD07051 RAM Replacement, Hard Drive: passo 7, imagem 2 %32
    • Use a Phillips #0 screwdriver (PH0 bit) to remove the four 6.0 mm screws that are securing the hard drive.
    Pergunte ao FixBot
    Comentar
  8. Asus X553MA-BPD07051 RAM Replacement: passo 8, imagem 1 %32 Asus X553MA-BPD07051 RAM Replacement: passo 8, imagem 2 %32
    • Lift the hard drive up and pull it towards the screen so that it disconnects from the motherboard.
    • Use caution when disconnecting the hard drive from the motherboard, so that neither connector gets broken.
    Pergunte ao FixBot
    Comentar
  9. Asus X553MA-BPD07051 RAM Replacement, Optical Drive: passo 9, imagem 1 %32 Asus X553MA-BPD07051 RAM Replacement, Optical Drive: passo 9, imagem 2 %32
    • Use a Phillips #0 screwdriver (PH0 bit) to remove the one 6.0 mm screw holding in the optical drive.
    Pergunte ao FixBot
    Comentar
  10. Asus X553MA-BPD07051 RAM Replacement: passo 10, imagem 1 %32 Asus X553MA-BPD07051 RAM Replacement: passo 10, imagem 2 %32
    • Gently slide the optical drive out from the motherboard.
    Pergunte ao FixBot
    Comentar
  11. Asus X553MA-BPD07051 RAM Replacement, Motherboard: passo 11, imagem 1 %32 Asus X553MA-BPD07051 RAM Replacement, Motherboard: passo 11, imagem 2 %32 Asus X553MA-BPD07051 RAM Replacement, Motherboard: passo 11, imagem 3 %32
    • Remove the bundled cable connector that connects the fan to the motherboard using the plastic iFixit opening tool.
    • Remove the bundled cable connector that attaches the audio to the motherboard with the plastic iFixit opening tool.
    Pergunte ao FixBot
    Comentar
  12. Asus X553MA-BPD07051 RAM Replacement: passo 12, imagem 1 %32 Asus X553MA-BPD07051 RAM Replacement: passo 12, imagem 2 %32
    • Lift the metal clip holding the ZIF connector ribbon down.
    • Pull the ribbon out from the connector, away from the motherboard.
    Pergunte ao FixBot
    Comentar
  13. Asus X553MA-BPD07051 RAM Replacement: passo 13, imagem 1 %32 Asus X553MA-BPD07051 RAM Replacement: passo 13, imagem 2 %32
    • Use a Phillips #0 screwdriver (PH0 bit) to remove the five 6.0 mm screws attaching the motherboard to the base of the laptop.
    Pergunte ao FixBot
    Comentar
  14. Asus X553MA-BPD07051 RAM Replacement: passo 14, imagem 1 %32
    • Remove the tape from the motherboard.
    Pergunte ao FixBot
    Comentar
  15. Asus X553MA-BPD07051 RAM Replacement: passo 15, imagem 1 %32 Asus X553MA-BPD07051 RAM Replacement: passo 15, imagem 2 %32
    • Lift the metal clips holding the ZIF connector down.
    • Push the gold metal connector away from the motherboard.
    • Be careful not to break the connector.
    Pergunte ao FixBot
    Comentar
  16. Asus X553MA-BPD07051 RAM Replacement: passo 16, imagem 1 %32 Asus X553MA-BPD07051 RAM Replacement: passo 16, imagem 2 %32
    • Lift the coaxial connector from the wifi chip with the plastic iFixit opening tool.
    Pergunte ao FixBot
    Comentar
  17. Asus X553MA-BPD07051 RAM Replacement: passo 17, imagem 1 %32 Asus X553MA-BPD07051 RAM Replacement: passo 17, imagem 2 %32 Asus X553MA-BPD07051 RAM Replacement: passo 17, imagem 3 %32
    • Lift the motherboard to remove it fully.
    • Do not pull too hard, the motherboard should come off easily once it has been separated from the base of the laptop.
    Pergunte ao FixBot
    Comentar
  18. Asus X553MA-BPD07051 RAM Replacement, RAM: passo 18, imagem 1 %32 Asus X553MA-BPD07051 RAM Replacement, RAM: passo 18, imagem 2 %32 Asus X553MA-BPD07051 RAM Replacement, RAM: passo 18, imagem 3 %32
    • Remove the RAM by lifting and pulling it up from the back of the motherboard.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 55
Ao todo: 2,744
