Ir para o conteúdo principal
Asus A53S Fan Assembly Replacement
O que você precisa
  1. Asus A53S Fan Assembly Replacement, Motherboard: passo 1, imagem 1 %32 Asus A53S Fan Assembly Replacement, Motherboard: passo 1, imagem 2 %32 Asus A53S Fan Assembly Replacement, Motherboard: passo 1, imagem 3 %32
    • Power off your device and remove the battery before beginning this guide.
    • Flip the laptop so the underside is facing up.
    • Using a Phillips #01 screwdriver, unscrew the two 6 mm screws.
    Pergunte ao FixBot
    Comentar
  2. Asus A53S Fan Assembly Replacement: passo 2, imagem 1 %32 Asus A53S Fan Assembly Replacement: passo 2, imagem 2 %32
    • Place a spudger under the white wire and pull it up gently, disconnecting it from the Wi-Fi card.
    • Use the same method on the black wire.
    Pergunte ao FixBot
    Comentar
  3. Asus A53S Fan Assembly Replacement: passo 3, imagem 1 %32 Asus A53S Fan Assembly Replacement: passo 3, imagem 2 %32 Asus A53S Fan Assembly Replacement: passo 3, imagem 3 %32
    • Push the hard drive to the left and remove it.
    Pergunte ao FixBot
    Comentar
  4. Asus A53S Fan Assembly Replacement: passo 4, imagem 1 %32 Asus A53S Fan Assembly Replacement: passo 4, imagem 2 %32
    • Using a Phillips #01 screwdriver, unscrew the fifteen 6 mm screws.
    Pergunte ao FixBot
    Comentar
  5. Asus A53S Fan Assembly Replacement: passo 5, imagem 1 %32 Asus A53S Fan Assembly Replacement: passo 5, imagem 2 %32
    • Flip over the laptop and open it.
    • Using the spudger, insert the flat end into the notches at the top of the keyboard and slowly "pop" the keyboard up and out of the device.
    Pergunte ao FixBot
    Comentar
  6. Asus A53S Fan Assembly Replacement: passo 6, imagem 1 %32 Asus A53S Fan Assembly Replacement: passo 6, imagem 2 %32
    • Using the flat end of the spudger, lift the black ZIF connector lock bar and disconnect the keyboard from the computer.
    • Remove the keyboard.
    Pergunte ao FixBot
    Comentar
  7. Asus A53S Fan Assembly Replacement: passo 7, imagem 1 %32 Asus A53S Fan Assembly Replacement: passo 7, imagem 2 %32
    • Using the spudger, place the flat end under the black lock bar holding the power switch. Push the spudger up and to the left, disconnecting the power switch.
    • Use the same technique on the touchpad to disconnect it.
    Pergunte ao FixBot
    Comentar
  8. Asus A53S Fan Assembly Replacement: passo 8, imagem 1 %32 Asus A53S Fan Assembly Replacement: passo 8, imagem 2 %32
    • Using a Phillips #01 screwdriver, unscrew the seven 6 mm screws.
    Pergunte ao FixBot
    Comentar
  9. Asus A53S Fan Assembly Replacement: passo 9, imagem 1 %32
    • Gently pull out the optical drive.
    Pergunte ao FixBot
    Comentar
  10. Asus A53S Fan Assembly Replacement: passo 10, imagem 1 %32
    • Flip the laptop back over so that the bottom is facing up.
    • Use a Phillips #01 screwdriver to unscrew the three 6 mm screws.
    Pergunte ao FixBot
    Comentar
  11. Asus A53S Fan Assembly Replacement: passo 11, imagem 1 %32 Asus A53S Fan Assembly Replacement: passo 11, imagem 2 %32
    • Turn the laptop back over so that you can open it.
    • Gently separate the cover from the laptop by putting an opening tool between the cover and the lower part of the laptop.
    Pergunte ao FixBot
    Comentar
  12. Asus A53S Fan Assembly Replacement: passo 12, imagem 1 %32
    • Remove the yellow tape.
    Pergunte ao FixBot
    Comentar
  13. Asus A53S Fan Assembly Replacement: passo 13, imagem 1 %32
    • Using the flat end of a spudger, flip ZIF connector lock bar up, disconnecting the USB board from the mother board.
    Pergunte ao FixBot
    Comentar
  14. Asus A53S Fan Assembly Replacement: passo 14, imagem 1 %32 Asus A53S Fan Assembly Replacement: passo 14, imagem 2 %32
    • Using the pointy end of a spudger, push upwards on the notches of the tan part of the LCD connector.
    Pergunte ao FixBot
    Comentar
  15. Asus A53S Fan Assembly Replacement: passo 15, imagem 1 %32 Asus A53S Fan Assembly Replacement: passo 15, imagem 2 %32
    • Using the pointy end of a spudger, gently push upwards on the black part of the speaker connector.
    Pergunte ao FixBot
    Comentar
  16. Asus A53S Fan Assembly Replacement: passo 16, imagem 1 %32 Asus A53S Fan Assembly Replacement: passo 16, imagem 2 %32
    • Using a Phillips #01 screwdriver, unscrew the five 6 mm screws at the indicated places.
    • Using a Phillips #01 screwdriver, unscrew the 5 mm screws.
    • All of these screws are indicated by a small white arrow.
    Pergunte ao FixBot
    Comentar
  17. Asus A53S Fan Assembly Replacement: passo 17, imagem 1 %32 Asus A53S Fan Assembly Replacement: passo 17, imagem 2 %32
    • Gently lift the motherboard, removing it from the laptop shell.
    Pergunte ao FixBot
    Comentar
  18. Asus A53S Fan Assembly Replacement, Fan Assembly: passo 18, imagem 1 %32 Asus A53S Fan Assembly Replacement, Fan Assembly: passo 18, imagem 2 %32 Asus A53S Fan Assembly Replacement, Fan Assembly: passo 18, imagem 3 %32
    • Flip the motherboard so that the fan and heat sink are facing up.
    • Pinch the upper part of the connector and pull upwards, slightly shimmying it side to side, to disconnect the fan.
    Pergunte ao FixBot
    Comentar
  19. Asus A53S Fan Assembly Replacement: passo 19, imagem 1 %32 Asus A53S Fan Assembly Replacement: passo 19, imagem 2 %32 Asus A53S Fan Assembly Replacement: passo 19, imagem 3 %32
    • Using a Phillips #01 screwdriver, unscrew the seven 5 mm screws.
    • Remove the fan assembly.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 41
Ao todo: 984
