Ir para o conteúdo principal
Astro A50 2016 Headset Motherboard Replacement
O que você precisa
  1. Astro A50 2016 Headset Motherboard Replacement, Headset Speakers: passo 1, imagem 1 %32 Astro A50 2016 Headset Motherboard Replacement, Headset Speakers: passo 1, imagem 2 %32
    • Remove the magnetic ear pads by gently pulling them away from the headset. Be careful not to remove the left earpad, which houses the microphone, and ensure you're only removing the right earpad.
    Pergunte ao FixBot
    Comentar
  2. Astro A50 2016 Headset Motherboard Replacement: passo 2, imagem 1 %32
    • Squeeze the plastic opening tool between the black plastic and foam pad on non mic side and then pry upwards to remove the felt pads covering the speaker.
    Pergunte ao FixBot
    Comentar
  3. Astro A50 2016 Headset Motherboard Replacement: passo 3, imagem 1 %32
    • Remove the four 6mm Phillips 1 screws.
    Pergunte ao FixBot
    Comentar
  4. Astro A50 2016 Headset Motherboard Replacement: passo 4, imagem 1 %32
    • Lift the speaker module up off the device.
    Pergunte ao FixBot
    Comentar
  5. Astro A50 2016 Headset Motherboard Replacement, Headset Motherboard: passo 5, imagem 1 %32
    Pergunte ao FixBot
    Comentar
  6. Astro A50 2016 Headset Motherboard Replacement: passo 6, imagem 1 %32 Astro A50 2016 Headset Motherboard Replacement: passo 6, imagem 2 %32
    • Use a soldering iron to desolder the black and yellow wires from the two metal plates near the bottom of the device.
    • Use a soldering iron to desolder the 13 wires in rows along the left and bottom sides of the headset motherboard.
    • Como soldar e dessoldar contatos
    Pergunte ao FixBot
    Comentar
  7. Astro A50 2016 Headset Motherboard Replacement: passo 7, imagem 1 %32
    • Use the plastic opening tool to pry off the black tape covering the gray wires
    Pergunte ao FixBot
    Comentar
  8. Astro A50 2016 Headset Motherboard Replacement: passo 8, imagem 1 %32
    • Lift the motherboard out of the headset and gently disconnect the gray wires from the motherboard.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Brian Menard
Membro desde: 10/01/17
306 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S15-G1, Livingston Fall 2017 Membro de Cal Poly, Team S15-G1, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G1
3 Membros
Autoria de 13 guias
2Comentários do guia
Any chance I could get the E250336. USB board part from you guys? I need one.
Theron Miller - Responder Compartilhar
I am having a very tough time finding this Part online. Thanks!
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 41
Ao todo: 4,891
