Ir para o conteúdo principal
Astro A50 2016 Headset Battery Replacement
O que você precisa
  1. Astro A50 2016  Headset Battery Replacement, Headset Speakers: passo 1, imagem 1 %32 Astro A50 2016  Headset Battery Replacement, Headset Speakers: passo 1, imagem 2 %32
    • Remove the magnetic ear pads by gently pulling them away from the headset. Be careful not to remove the left earpad, which houses the microphone, and ensure you're only removing the right earpad.
    Pergunte ao FixBot
    Comentar
  2. Astro A50 2016  Headset Battery Replacement: passo 2, imagem 1 %32
    • Squeeze the plastic opening tool between the black plastic and foam pad on non mic side and then pry upwards to remove the felt pads covering the speaker.
    Pergunte ao FixBot
    Comentar
  3. Astro A50 2016  Headset Battery Replacement: passo 3, imagem 1 %32
    • Remove the four 6mm Phillips 1 screws.
    Pergunte ao FixBot
    Comentar
  4. Astro A50 2016  Headset Battery Replacement: passo 4, imagem 1 %32
    • Lift the speaker module up off the device.
    Pergunte ao FixBot
    Comentar
  5. Astro A50 2016  Headset Battery Replacement, Headset Battery: passo 5, imagem 1 %32 Astro A50 2016  Headset Battery Replacement, Headset Battery: passo 5, imagem 2 %32
    • Remove the five 6mm PH1 screws.
    • Remove the buttons panel by pulling the panel away from the white ribbon cord.
    Pergunte ao FixBot
    Comentar
  6. Astro A50 2016  Headset Battery Replacement: passo 6, imagem 1 %32 Astro A50 2016  Headset Battery Replacement: passo 6, imagem 2 %32
    • Remove the four 6mm PH1 screws.
    • Remove the tape holding the wires connected to the motherboard.
    Pergunte ao FixBot
    Comentar
  7. Astro A50 2016  Headset Battery Replacement: passo 7, imagem 1 %32
    • Remove the back panel by squeezing the two tabs together and pushing out.
    Pergunte ao FixBot
    Comentar
  8. Astro A50 2016  Headset Battery Replacement: passo 8, imagem 1 %32
    Pergunte ao FixBot
    Comentar
  9. Astro A50 2016  Headset Battery Replacement: passo 9, imagem 1 %32
    • Remove the battery by using the plastic opening tool to pry it away from the headset.
    Pergunte ao FixBot
    Comentar
Conclusão
14 outras pessoas executaram este guia.
Equipe
Cal Poly, Team S15-G1, Livingston Fall 2017 Membro de Cal Poly, Team S15-G1, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G1
3 Membros
Autoria de 13 guias
15Comentários do guia
Is this for the Gen III Astro a50?
vic.bianco - Responder Compartilhar
Yes it’s for the Gen 3 A50
Crisdavid - Responder Compartilhar
Where do I buy a battery though….
Brandon Phillips - Responder Compartilhar
how can I connect the new battery ?
Ahmed f - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 37
Últimos 30 dias: 213
Ao todo: 32,102
