Introdução
Use this guide to replace a broken, cracked, or defective display on your Apple Watch SE.
Replacing the display can cause issues with Apple Pay. If possible, to reduce the likelihood of problems, delete all your Apple Pay account info before the replacement, and then re-enter it with the new display installed.
You’ll need replacement adhesive to reattach components when reassembling the device.
O que você precisa
Before starting repairs, take your watch off the charger and power it down.
If your touchscreen is broken and you can't power off the watch, use this alternate method to power it down.
Ferramenta utilizada neste passo:Safety Glasses$3.19
Because the gap between the screen and watch body is so thin, a sharp blade is needed to separate the two. Read the following warnings carefully before proceeding.
Prepare an iOpener (or use a hair dryer or heat gun) and heat the face of the watch to loosen the display adhesive.
Leave the iOpener on the watch for at least two minutes to fully heat the screen and soften the adhesive holding it to the case.
You should have coherent instructions…like how long to heat the iopener in the microwave in these instructioms. Seems like you are not ready for prime time with your product
Place the edge of a curved blade into the thin gap between the display and the outer case. Start at the short side of the display, closest to the digital crown.
Press firmly straight down into the gap.
Once inserted, tilt the blade to pry the display open slightly.
Prepare an iOpener (or use a hair dryer or heat gun) and heat the face of the watch to loosen the adhesive tape.
Alternatively, apply a little bit of high-concentration isopropyl alcohol (>90%) to a Q-tip and apply it to the black adhesive foil on top of the display connectors. Let it penetrate the adhesive for about two minutes.
This is impossible. The tape will rip even if you use isoprpyl alcohol AND the iopener.
Ferramenta utilizada neste passo:Tweezers$4.99
Use a pair of tweezers to carefully peel off the tape covering the right display cable connector.
Use the pointed end of a spudger to open the right ZIF connector on the rear side of the display by bringing its flap in an upright position.
Use a pair of tweezers to peel the left edge off the display cable sticker off the rear side of the display.
Again: impossible. Peeling the edges away destroys the cables on the sides. I now have the damaged face nicely removed but the side cales are destroeyd.
Carefully pull the display flex cables out of their ZIF connectors.
Separate the watch assembly and the display.
To reassemble your Apple Watch SE follow these instructions in reverse order to reattach the screen and the battery.
Apply a little bit of high isopropyl alcohol (>90%) to a Q-tip or use a cleaning pad to gently remove the leftover adhesive on the edges of the watch case and the screen before installing new adhesive.
37 outras pessoas executaram este guia.
8 comentários
any idea where I can purchase the replacement screen itself?
Will I be able to preserve the NFC antenna after replacing the screen?
This was as simple as presented, and it still really did take me an hour and a half to complete. The old screen was shattered and just turned into glass splinters when I took it out, so it required digging out the entire adhesive seal caked with glass bits with the curved bladed knife. In my case, I am very glad I also bought the Tesa 61395 Tape - New / Precut Double-Sided Adhesive Card to form a new seal or else the new screen would not have stayed put.
Will the new NFC chip prevent the Apple Watch from being updated in the future?
