Ir para o conteúdo principal
Apple Pencil (2nd Generation) Tips Replacement
O que você precisa
  1. Apple Pencil (2nd Generation) Tips Replacement, Preparation: passo 1, imagem 1 %32 Apple Pencil (2nd Generation) Tips Replacement, Preparation: passo 1, imagem 2 %32 Apple Pencil (2nd Generation) Tips Replacement, Preparation: passo 1, imagem 3 %32
    • Grab your Apple Pencil Generation 2.
    • Make sure you have replacement tips. You can buy them from Apple or Amazon.
  2. Apple Pencil (2nd Generation) Tips Replacement, Unscrewing and Installing the tip: passo 2, imagem 1 %32
    • To take off your Apple Pencil's current tip, squeeze it between two fingers and turn it counterclockwise to unscrew it. It should come off within seconds.
    • Once it's off, place your new Pencil tip on the metal prong and screw it clockwise until it's tight. Once it stops turning easily, you can let go.
Conclusão
tayola
Membro desde: 07/21/22
9.523 Reputação
Autoria de 44 guias
Equipe
Kid fixers Membro de Kid fixers
Community
187 Membros
Autoria de 257 guias
2Comentários do guia
Ich habe das Problem, daß der "Hals" der Kunststoffspitze im Pencil steckt. Ich bekomme ihn nicht heraus. Hat jemand eine Lösung?
Busso - Responder
Comentar
Visualizações:
Últimas 24 horas: 10
Últimos 7 dias: 117
Últimos 30 dias: 563
Ao todo: 20,859
