Ir para o conteúdo principal
Apple Pencil (2nd Generation) Tips Replacement
O que você precisa
  1. Apple Pencil (2nd Generation) Tips Replacement, Preparation: passo 1, imagem 1 %32 Apple Pencil (2nd Generation) Tips Replacement, Preparation: passo 1, imagem 2 %32 Apple Pencil (2nd Generation) Tips Replacement, Preparation: passo 1, imagem 3 %32
    • Grab your Apple Pencil Second Generation.
    • Make sure you have replacement tips. You can buy them from Apple or from 3rd party vendors on Amazon.
  2. Apple Pencil (2nd Generation) Tips Replacement, Unscrewing and Installing the tip: passo 2, imagem 1 %32
    • To take off your Apple Pencil's current tip, squeeze it between two fingers and turn it counterclockwise to unscrew it. It should come off within seconds.
    • Once it's off, place your new Pencil tip on the metal prong and screw it clockwise until it's tight. Once it stops turning easily, you can let go.
Conclusão
tayola
Membro desde: 07/21/22
9.877 Reputação
Autoria de 44 guias
3Comentários do guia
Ich habe das Problem, daß der "Hals" der Kunststoffspitze im Pencil steckt. Ich bekomme ihn nicht heraus. Hat jemand eine Lösung?
Busso - Responder
Is there a guide to actually fix a broken tip for the 2nd gen?
We have staff who've had the tip break and the base of it remains lodged in the tip receptacle.
Adam Macks - Responder
Comentar
Visualizações:
Últimas 24 horas: 19
Últimos 7 dias: 113
Últimos 30 dias: 601
Ao todo: 25,988
