Ir para o conteúdo principal
Anker Soundcore Motion Boom Plus Tweeter Replacement
O que você precisa
  1. Anker Soundcore Motion Boom Plus Tweeter Replacement, Case: passo 1, imagem 1 %32 Anker Soundcore Motion Boom Plus Tweeter Replacement, Case: passo 1, imagem 2 %32 Anker Soundcore Motion Boom Plus Tweeter Replacement, Case: passo 1, imagem 3 %32
    • Insert an opening tool into the seam between the speaker grille and the chassis.
    • Pry the tool around the top, bottom, and sides until the grille fully releases.
    • Apply gentle pressure to avoid damaging the grille.
    • Remove the grille.
    Pergunte ao FixBot
    Comentar
  2. Anker Soundcore Motion Boom Plus Tweeter Replacement: passo 2, imagem 1 %32 Anker Soundcore Motion Boom Plus Tweeter Replacement: passo 2, imagem 2 %32
    • Remove the two passive radiators on either side of the device.
    • Avoid pulling too hard or with too much force to prevent breaking the passive radiators.
    Pergunte ao FixBot
    Comentar
  3. Anker Soundcore Motion Boom Plus Tweeter Replacement: passo 3, imagem 1 %32 Anker Soundcore Motion Boom Plus Tweeter Replacement: passo 3, imagem 2 %32
    • Remove the sixteen 14 mm Phillips screws, eight on each end of the speaker.
    Pergunte ao FixBot
    Comentar
  4. Anker Soundcore Motion Boom Plus Tweeter Replacement: passo 4, imagem 1 %32 Anker Soundcore Motion Boom Plus Tweeter Replacement: passo 4, imagem 2 %32 Anker Soundcore Motion Boom Plus Tweeter Replacement: passo 4, imagem 3 %32
    • Gently remove the handle from the device by clicking off the handles from the sides and then pulling it off.
    Pergunte ao FixBot
    Comentar
  5. Anker Soundcore Motion Boom Plus Tweeter Replacement: passo 5, imagem 1 %32 Anker Soundcore Motion Boom Plus Tweeter Replacement: passo 5, imagem 2 %32
    • Flip the speaker onto its side and use a spudger to remove the two rubber feet on the bottom of the device.
    Pergunte ao FixBot
    Comentar
  6. Anker Soundcore Motion Boom Plus Tweeter Replacement: passo 6, imagem 1 %32 Anker Soundcore Motion Boom Plus Tweeter Replacement: passo 6, imagem 2 %32
    • Remove the eleven 13 mm Philips screws that secure the driver housing.
    Pergunte ao FixBot
    Comentar
  7. Anker Soundcore Motion Boom Plus Tweeter Replacement: passo 7, imagem 1 %32 Anker Soundcore Motion Boom Plus Tweeter Replacement: passo 7, imagem 2 %32
    • Remove the two 14 mm Phillips screws located on each side of the handle, near the clip points.
    Pergunte ao FixBot
    Comentar
  8. Anker Soundcore Motion Boom Plus Tweeter Replacement: passo 8, imagem 1 %32 Anker Soundcore Motion Boom Plus Tweeter Replacement: passo 8, imagem 2 %32
    • Remove the four 14 mm Philips screws on the top of the device.
    Pergunte ao FixBot
    Comentar
  9. Anker Soundcore Motion Boom Plus Tweeter Replacement: passo 9, imagem 1 %32
    • Insert a spudger into the seam on top of the device.
    • Gently pry the casing open.
    Pergunte ao FixBot
    Comentar
  10. Anker Soundcore Motion Boom Plus Tweeter Replacement: passo 10, imagem 1 %32 Anker Soundcore Motion Boom Plus Tweeter Replacement: passo 10, imagem 2 %32 Anker Soundcore Motion Boom Plus Tweeter Replacement: passo 10, imagem 3 %32
    • Disconnect each of the three cables by gently pulling the connectors out of their sockets.
    • Do not pull with force. The ribbon cables are fragile and easily break.
    Pergunte ao FixBot
    Comentar
  11. Anker Soundcore Motion Boom Plus Tweeter Replacement, Tweeter: passo 11, imagem 1 %32 Anker Soundcore Motion Boom Plus Tweeter Replacement, Tweeter: passo 11, imagem 2 %32
    • Disconnect the ribbon cables attached to the tweeters by pulling them off gently.
    • Avoid pulling too hard on the ribbon cables as they are fragile and easily break.
    Pergunte ao FixBot
    Comentar
  12. Anker Soundcore Motion Boom Plus Tweeter Replacement: passo 12, imagem 1 %32
    • Push the tweeters from the front side, and the tweeters should pop out. Remove and replace the tweeters with new ones.
    Pergunte ao FixBot
    Comentar
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Hayley
Membro desde: 03/26/25
988 Reputação
Autoria de 6 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 32
Ao todo: 298
