Ir para o conteúdo principal
Anker Soundcore Motion 300 Drivers Replacement
O que você precisa
  1. Anker Soundcore Motion 300 Drivers Replacement, Speaker Grille: passo 1, imagem 1 %32 Anker Soundcore Motion 300 Drivers Replacement, Speaker Grille: passo 1, imagem 2 %32
    • Insert an opening tool into a seam between the grille and chassis.
    • Gently pry the grille up to begin disengaging the retaining clip.
    • Once a corner starts to lift, slowly slide the tool along the edge to loosen more of the grille.
    Pergunte ao FixBot
    Comentar
  2. Anker Soundcore Motion 300 Drivers Replacement: passo 2, imagem 1 %32 Anker Soundcore Motion 300 Drivers Replacement: passo 2, imagem 2 %32
    • Keep working around the edges until all the clips are loose.
    • You may hear soft clicking sounds as the clips come undone.
    Pergunte ao FixBot
    Comentar
  3. Anker Soundcore Motion 300 Drivers Replacement: passo 3, imagem 1 %32
    • Carefully remove the grille from the speaker.
    Pergunte ao FixBot
    Comentar
  4. Anker Soundcore Motion 300 Drivers Replacement, Drivers: passo 4, imagem 1 %32 Anker Soundcore Motion 300 Drivers Replacement, Drivers: passo 4, imagem 2 %32 Anker Soundcore Motion 300 Drivers Replacement, Drivers: passo 4, imagem 3 %32
    • Use a Phillips #0 screwdriver to remove all eight 11.5 mm screws that secure the driver housing.
    Pergunte ao FixBot
    Comentar
  5. Anker Soundcore Motion 300 Drivers Replacement: passo 5, imagem 1 %32 Anker Soundcore Motion 300 Drivers Replacement: passo 5, imagem 2 %32 Anker Soundcore Motion 300 Drivers Replacement: passo 5, imagem 3 %32
    • Use an opening tool to pry up the speaker housing.
    • Set the speaker housing beside the speaker, with care not to strain the cables connected to the drivers.
    • The speaker housing may be very difficult to remove due to adhesive. If necessary, use a hairdryer to lightly heat the perimeter of the housing to loosen the adhesive.
    Pergunte ao FixBot
    Comentar
  6. Anker Soundcore Motion 300 Drivers Replacement: passo 6, imagem 1 %32 Anker Soundcore Motion 300 Drivers Replacement: passo 6, imagem 2 %32 Anker Soundcore Motion 300 Drivers Replacement: passo 6, imagem 3 %32
    • With a Phillips #0 screwdriver, remove the four 7.5 mm screws that secure the driver.
    • Repeat the previous bullet for the other driver.
    • Gently lift off the drivers; the speakers may be slightly glued or stuck to the plastic plate so try not pull on the wiring attaching the components.
    • Disconnect each of the the two driver connectors from the motherboard.
    • There may be a small piece of sealant that must be removed before the connectors can be removed.
    • Remove the drivers.
    Pergunte ao FixBot
    Comentar
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 19
Últimos 30 dias: 75
Ao todo: 595
