Ir para o conteúdo principal
Anker Soundcore Motion 300 Battery Replacement
O que você precisa
  1. Anker Soundcore Motion 300 Battery Replacement, Speaker Grille: passo 1, imagem 1 %32 Anker Soundcore Motion 300 Battery Replacement, Speaker Grille: passo 1, imagem 2 %32
    • Insert an opening tool into a seam between the grille and chassis.
    • Gently pry the grille up to begin disengaging the retaining clip.
    • Once a corner starts to lift, slowly slide the tool along the edge to loosen more of the grille.
    Pergunte ao FixBot
  2. Anker Soundcore Motion 300 Battery Replacement: passo 2, imagem 1 %32 Anker Soundcore Motion 300 Battery Replacement: passo 2, imagem 2 %32
    • Keep working around the edges until all the clips are loose.
    • You may hear soft clicking sounds as the clips come undone.
    Pergunte ao FixBot
  3. Anker Soundcore Motion 300 Battery Replacement: passo 3, imagem 1 %32
    • Carefully remove the grille from the speaker.
    Pergunte ao FixBot
  4. Anker Soundcore Motion 300 Battery Replacement, Battery: passo 4, imagem 1 %32 Anker Soundcore Motion 300 Battery Replacement, Battery: passo 4, imagem 2 %32 Anker Soundcore Motion 300 Battery Replacement, Battery: passo 4, imagem 3 %32
    • Use a Phillips #0 screwdriver to remove all eight 11.5 mm screws that secure the driver housing.
    Pergunte ao FixBot
  5. Anker Soundcore Motion 300 Battery Replacement: passo 5, imagem 1 %32 Anker Soundcore Motion 300 Battery Replacement: passo 5, imagem 2 %32 Anker Soundcore Motion 300 Battery Replacement: passo 5, imagem 3 %32
    • Use an opening tool to pry up the speaker housing.
    • Set the speaker housing beside the speaker, with care not to strain the cables connected to the drivers.
    • The speaker housing may be very difficult to remove due to adhesive. If necessary, use a hairdryer to lightly heat the perimeter of the housing to loosen the adhesive.
    Pergunte ao FixBot
  6. Anker Soundcore Motion 300 Battery Replacement: passo 6, imagem 1 %32 Anker Soundcore Motion 300 Battery Replacement: passo 6, imagem 2 %32 Anker Soundcore Motion 300 Battery Replacement: passo 6, imagem 3 %32
    • Use tweezers to remove the sealant that secures the battery connector.
    • Pull the battery connector directly out of its port.
    • Lift the battery up and out of the chassis.
    Pergunte ao FixBot
Conclusão
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 40
Ao todo: 770
