Ir para o conteúdo principal
Anker Soundcore Life Q20 Buttons Replacement
O que você precisa
  1. Anker Soundcore Life Q20 Buttons Replacement, Ear Cushion: passo 1, imagem 1 %32
    • Choose the desired ear cushion to replace.
    • Orient the headphones so that the side of the ear cushion is accessible.
    Pergunte ao FixBot
    Comentar
  2. Anker Soundcore Life Q20 Buttons Replacement: passo 2, imagem 1 %32 Anker Soundcore Life Q20 Buttons Replacement: passo 2, imagem 2 %32
    • Wedge the iFixit opening tool into the groove where the ear cushion meets the base of the headphones.
    • Pry the ear cushion apart from the base.
    Pergunte ao FixBot
    Comentar
  3. Anker Soundcore Life Q20 Buttons Replacement: passo 3, imagem 1 %32 Anker Soundcore Life Q20 Buttons Replacement: passo 3, imagem 2 %32
    • Repeat step 2 in a rotation around the ear cushion until it is fully detached from the base.
    Pergunte ao FixBot
    Comentar
  4. Anker Soundcore Life Q20 Buttons Replacement, Battery: passo 4, imagem 1 %32 Anker Soundcore Life Q20 Buttons Replacement, Battery: passo 4, imagem 2 %32 Anker Soundcore Life Q20 Buttons Replacement, Battery: passo 4, imagem 3 %32
    • Use a Phillips #00 screwdriver to remove the four 10 mm screws from the cover.
    • Remove the cover to expose the battery.
    Pergunte ao FixBot
    Comentar
  5. Anker Soundcore Life Q20 Buttons Replacement: passo 5, imagem 1 %32
    • Use your index finger to lift the battery and remove it from the base.
    • Desolder the battery from the board, following the instructions from the iFixit soldering guide: Como soldar e dessoldar contatos
    Pergunte ao FixBot
    Comentar
  6. Anker Soundcore Life Q20 Buttons Replacement, Buttons: passo 6, imagem 1 %32
    • Using the Phillips #00 screwdriver, remove the two 7 mm screws from the green board.
    Pergunte ao FixBot
    Comentar
  7. Anker Soundcore Life Q20 Buttons Replacement: passo 7, imagem 1 %32
    • Press the buttons as usual to pop them out of the base.
    • Gently pull the remaining tabs inside the base to disconnect the buttons.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 23
Ao todo: 394
