Ir para o conteúdo principal
Anker SoundCore 2 Speaker Replacement
O que você precisa
  1. Anker SoundCore 2 Speaker Replacement, Front Panel: passo 1, imagem 1 %32 Anker SoundCore 2 Speaker Replacement, Front Panel: passo 1, imagem 2 %32
    • Insert a spudger between the front panel and the body of the speaker.
    • Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
    Pergunte ao FixBot
    Comentar
  2. Anker SoundCore 2 Speaker Replacement, Speaker: passo 2, imagem 1 %32 Anker SoundCore 2 Speaker Replacement, Speaker: passo 2, imagem 2 %32 Anker SoundCore 2 Speaker Replacement, Speaker: passo 2, imagem 3 %32
    • Remove eight 10 mm screws from the speaker mount using a Phillips #0 screwdriver.
    • Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
    • Use your hand to remove the speakers.
    Pergunte ao FixBot
    Comentar
  3. Anker SoundCore 2 Speaker Replacement: passo 3, imagem 1 %32 Anker SoundCore 2 Speaker Replacement: passo 3, imagem 2 %32 Anker SoundCore 2 Speaker Replacement: passo 3, imagem 3 %32
    • The speakers do not use wires so when replacing the speaker, make sure you align the metal prongs with the metal clips on the motherboard.
    Pergunte ao FixBot
    Comentar
Conclusão
4 outras pessoas executaram este guia.
13Comentários do guia
Excellent guide, my speaker falls to the ground, and one of two speaker stops working, disassemble and verifying, was the speaker clip was loose
Renato Galindo - Responder Compartilhar
Where can I buy a speaker for the repair ? Or will any sized speaker work ?
philcuchetti - Responder Compartilhar
hi, did you manage to buy a replacement speaker? If yes from where pls?
jafarez - Responder Compartilhar
@philcuchetti I have a soundcore select 1 which is an older model and it seems to have the same speaker which I found here https://www.aliexpress.com/item/10050091...
JSound - Responder Compartilhar
Do someone get a new speaker? I need to buy one!
everton.euclides - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 42
Últimos 30 dias: 136
Ao todo: 7,368
