Ir para o conteúdo principal
Anker SoundCore 2 Charging Port Replacement
O que você precisa
  1. Anker SoundCore 2 Charging Port Replacement, Front Panel: passo 1, imagem 1 %32 Anker SoundCore 2 Charging Port Replacement, Front Panel: passo 1, imagem 2 %32
    • Insert a spudger between the front panel and the body of the speaker.
    • Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
  2. Anker SoundCore 2 Charging Port Replacement, Motherboard: passo 2, imagem 1 %32 Anker SoundCore 2 Charging Port Replacement, Motherboard: passo 2, imagem 2 %32 Anker SoundCore 2 Charging Port Replacement, Motherboard: passo 2, imagem 3 %32
    • Remove eight 10 mm screws from the speaker mount using a Phillips #0 screwdriver.
    • Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
    • Use your hand to remove the speakers.
  3. Anker SoundCore 2 Charging Port Replacement: passo 3, imagem 1 %32 Anker SoundCore 2 Charging Port Replacement: passo 3, imagem 2 %32 Anker SoundCore 2 Charging Port Replacement: passo 3, imagem 3 %32
    • Remove the 10 mm screw that is holding the motherboard in place using a Phillips #0 screwdriver.
    • Flip up the motherboard and disconnect the cord that connects the motherboard and the battery.
  4. Anker SoundCore 2 Charging Port Replacement, Charging Port: passo 4, imagem 1 %32 Anker SoundCore 2 Charging Port Replacement, Charging Port: passo 4, imagem 2 %32
    • Desolder the charging port from the motherboard and solder a new one on.
    • For help with soldering and desoldering, follow this guide.
Conclusão
3 outras pessoas executaram este guia.
4 comentários
Hello please what's the model of the ESD4 and C34 close to the charging port?
Abel Omeokwe - Responder
Where can i get a replacement charging Port?
A K - Responder
what's the micro usb port part number? I want to replace it but can't find info on it anywhere.
Tomasz Konwalski - Responder
I've made the replacement, but with a spare type c port and...it's not working. Can someone help?
Delyan - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 32
Últimos 30 dias: 144
Duração total: 2,272
