Introdução
Use this guide to replace a dead or worn out battery in your Analogue Pocket.
Note: This guide shows how to replace the battery cell and its housing as one assembly. If you're replacing the battery cell itself, follow this guide to extract it from its housing.
O que você precisa
Unplug all cables and fully power off your device.
Working on your device requires laying it screen-side down. To prevent damage, lay it on a soft surface such as a towel.
Use a T6 Torx screwdriver to remove the four 13.4 mm‑long screws securing the battery shell.
Lift the bottom edge of the battery shell to unhook its tabs.
Remove the battery shell.
Use blunt nose tweezers to pull the battery connector out of its socket on the bottom right corner of your device.
Lift one of the battery's short edges until the clips release.
Remove the battery.
For optimal performance, calibrate your newly installed battery after completing this guide.
