Ir para o conteúdo principal
Analogue Pocket Battery Replacement
O que você precisa
  1. Analogue Pocket Battery Replacement, Prepare your device for disassembly: passo 1, imagem 1 %32 Analogue Pocket Battery Replacement, Prepare your device for disassembly: passo 1, imagem 2 %32 Analogue Pocket Battery Replacement, Prepare your device for disassembly: passo 1, imagem 3 %32
    • Unplug all cables and fully power off your device.
    • Working on your device requires laying it screen-side down. To prevent damage, lay it on a soft surface such as a towel.
  2. Analogue Pocket Battery Replacement, Unfasten the battery shell: passo 2, imagem 1 %32 Analogue Pocket Battery Replacement, Unfasten the battery shell: passo 2, imagem 2 %32
    • Use a T6 Torx screwdriver to remove the four 13.4 mm‑long screws securing the battery shell.
  3. Analogue Pocket Battery Replacement, Remove the battery shell: passo 3, imagem 1 %32 Analogue Pocket Battery Replacement, Remove the battery shell: passo 3, imagem 2 %32 Analogue Pocket Battery Replacement, Remove the battery shell: passo 3, imagem 3 %32
  4. Analogue Pocket Battery Replacement, Disconnect the battery: passo 4, imagem 1 %32 Analogue Pocket Battery Replacement, Disconnect the battery: passo 4, imagem 2 %32 Analogue Pocket Battery Replacement, Disconnect the battery: passo 4, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use blunt nose tweezers to pull the battery connector out of its socket on the bottom right corner of your device.
    • If you're having trouble, try rocking the connector side-to-side to help loosen it.
    • During reassembly, use the flat end of a spudger to push down on the edges of the connector until it's secure in the socket.
  5. Analogue Pocket Battery Replacement, Remove the battery: passo 5, imagem 1 %32 Analogue Pocket Battery Replacement, Remove the battery: passo 5, imagem 2 %32 Analogue Pocket Battery Replacement, Remove the battery: passo 5, imagem 3 %32
    • Lift one of the battery's short edges until the clips release.
    • Remove the battery.
    • During reassembly, push the battery into its recess until the clips engage.
Conclusão
For optimal performance, calibrate your newly installed battery after completing this guide.
Spencer Day
Membro desde: 09/14/22
61.610 Reputação
Autoria de 445 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 140
Autoria de 18.076 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 59
Últimos 30 dias: 206
Duração total: 2,232
