Ir para o conteúdo principal
Altec Lansing Mini Lifejacket 2 Speaker Replacement
O que você precisa
  1. Altec Lansing Mini Lifejacket 2 Speaker Replacement, Back Panel: passo 1, imagem 1 %32 Altec Lansing Mini Lifejacket 2 Speaker Replacement, Back Panel: passo 1, imagem 2 %32 Altec Lansing Mini Lifejacket 2 Speaker Replacement, Back Panel: passo 1, imagem 3 %32
    • Use the spudger to remove the eight black pins from the front and back of the wire screens.
    Pergunte ao FixBot
    Comentar
  2. Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 2, imagem 1 %32 Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 2, imagem 2 %32 Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 2, imagem 3 %32
    • Detach the eight secondary pins from the front and back of the wire mesh plates with a spudger.
    • Removing the secondary pins from the rubber casing is optional.
    Pergunte ao FixBot
    Comentar
  3. Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 3, imagem 1 %32 Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 3, imagem 2 %32
    • Remove both black and orange layers from the speaker body.
    Pergunte ao FixBot
    Comentar
  4. Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 4, imagem 1 %32 Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 4, imagem 2 %32 Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 4, imagem 3 %32
    • Remove the single 7.8mm Phillips #2 screw from the mounting plate located under the device.
    • Slide the mounting plate out to remove it.
    Pergunte ao FixBot
    Comentar
  5. Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 5, imagem 1 %32 Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 5, imagem 2 %32
    • Pry off the wire mesh on both sides using a metal spudger.
    • Be gentle to avoid bending the mesh.
    Pergunte ao FixBot
    Comentar
  6. Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 6, imagem 1 %32 Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 6, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Using tweezers, remove the four rubber stoppers in each corner of the rear panel.
    Pergunte ao FixBot
    Comentar
  7. Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 7, imagem 1 %32
    • Remove the four 13.7mm Phillips #1 screws located underneath the rubber stoppers.
    Pergunte ao FixBot
    Comentar
  8. Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 8, imagem 1 %32
    • Pull the case apart to access the interior components.
    Pergunte ao FixBot
    Comentar
  9. Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 9, imagem 1 %32 Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 9, imagem 2 %32 Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 9, imagem 3 %32
    • To remove the back panel, gently pull out its wire harness.
    Pergunte ao FixBot
    Comentar
  10. Altec Lansing Mini Lifejacket 2 Speaker Replacement, Speaker: passo 10, imagem 1 %32 Altec Lansing Mini Lifejacket 2 Speaker Replacement, Speaker: passo 10, imagem 2 %32
    • Remove the three 9.3 mm Phillips #1 screws on the speaker cover.
    Pergunte ao FixBot
    Comentar
  11. Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 11, imagem 1 %32 Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 11, imagem 2 %32 Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 11, imagem 3 %32
    • To remove the speaker, gently pull out the its wire harness.
    Pergunte ao FixBot
    Comentar
  12. Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 12, imagem 1 %32 Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 12, imagem 2 %32
    • Remove the rubber ring from the rim of the speaker.
    • This ring helps keep water from entering the device. Be careful to position it correctly during reassembly.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Stephen Albrecht
Membro desde: 02/14/18
1.053 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S3-G2, Nance Spring 2018 Membro de USF Tampa, Team S3-G2, Nance Spring 2018
USFT-NANCE-S18S3G2
4 Membros
Autoria de 4 guias
3Comentários do guia
What speaker should we be getting to replace the faulty speaker, including the wires needed to plug into the slots on the board?
russell rogge - Responder Compartilhar
Where can I get this speaker parts?
T Rex movies - Responder Compartilhar
Where can I get a complete power circuit board from for a Imw575 as mine is completely broken thank you
Paul Williams - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 50
Ao todo: 4,979
