Ir para o conteúdo principal
Altec Lansing Mini Lifejacket 2 Motherboard Replacement
O que você precisa
  1. Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Back Panel: passo 1, imagem 1 %32 Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Back Panel: passo 1, imagem 2 %32 Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Back Panel: passo 1, imagem 3 %32
    • Use the spudger to remove the eight black pins from the front and back of the wire screens.
    Pergunte ao FixBot
    Comentar
  2. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: passo 2, imagem 1 %32 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: passo 2, imagem 2 %32 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: passo 2, imagem 3 %32
    • Detach the eight secondary pins from the front and back of the wire mesh plates with a spudger.
    • Removing the secondary pins from the rubber casing is optional.
    Pergunte ao FixBot
    Comentar
  3. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: passo 3, imagem 1 %32 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: passo 3, imagem 2 %32
    • Remove both black and orange layers from the speaker body.
    Pergunte ao FixBot
    Comentar
  4. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: passo 4, imagem 1 %32 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: passo 4, imagem 2 %32 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: passo 4, imagem 3 %32
    • Remove the single 7.8mm Phillips #2 screw from the mounting plate located under the device.
    • Slide the mounting plate out to remove it.
    Pergunte ao FixBot
    Comentar
  5. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: passo 5, imagem 1 %32 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: passo 5, imagem 2 %32
    • Pry off the wire mesh on both sides using a metal spudger.
    • Be gentle to avoid bending the mesh.
    Pergunte ao FixBot
    Comentar
  6. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: passo 6, imagem 1 %32 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: passo 6, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Using tweezers, remove the four rubber stoppers in each corner of the rear panel.
    Pergunte ao FixBot
    Comentar
  7. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: passo 7, imagem 1 %32
    • Remove the four 13.7mm Phillips #1 screws located underneath the rubber stoppers.
    Pergunte ao FixBot
    Comentar
  8. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: passo 8, imagem 1 %32
    • Pull the case apart to access the interior components.
    Pergunte ao FixBot
    Comentar
  9. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: passo 9, imagem 1 %32 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: passo 9, imagem 2 %32 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: passo 9, imagem 3 %32
    • To remove the back panel, gently pull out its wire harness.
    Pergunte ao FixBot
    Comentar
  10. Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Battery: passo 10, imagem 1 %32 Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Battery: passo 10, imagem 2 %32 Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Battery: passo 10, imagem 3 %32
    • Disconnect the battery from the motherboard.
    • The battery is not secured within the case and can be removed after detaching its wiring from the circuit board.
    Pergunte ao FixBot
    Comentar
  11. Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Motherboard: passo 11, imagem 1 %32 Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Motherboard: passo 11, imagem 2 %32 Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Motherboard: passo 11, imagem 3 %32
    • Unplug the remaining four wire harnesses attached to the circuit board
    Pergunte ao FixBot
    Comentar
  12. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: passo 12, imagem 1 %32 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: passo 12, imagem 2 %32
    • Remove the three 9.1mm Phillips #1 screws located on the circuit board.
    Pergunte ao FixBot
    Comentar
  13. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: passo 13, imagem 1 %32 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: passo 13, imagem 2 %32 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: passo 13, imagem 3 %32
    • Remove the motherboard.
    Pergunte ao FixBot
    Comentar
Conclusão
Stephen Albrecht
Membro desde: 02/14/18
1.053 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S3-G2, Nance Spring 2018 Membro de USF Tampa, Team S3-G2, Nance Spring 2018
USFT-NANCE-S18S3G2
4 Membros
Autoria de 4 guias
6Comentários do guia
I own the IMW778-BLU-TA model. Where can I find a replacement motherboard for it??
Nick Cote - Responder Compartilhar
same for me, anyone knows where can I find a replacement of the motherboard? thx
Travis - Responder Compartilhar
need back panel replacement
rahul pande - Responder Compartilhar
Same here! Loved the product. Can not afford to buy something else.
Mr Shopper - Responder Compartilhar
I need 2 the board for charging,usb,aux cord that plugs into motherboard.
John Proffit - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 50
Ao todo: 6,356
