Ir para o conteúdo principal
Altec Lansing Mini Lifejacket 2 Battery Replacement
O que você precisa
  1. Altec Lansing Mini Lifejacket 2 Battery Replacement, Back Panel: passo 1, imagem 1 %32 Altec Lansing Mini Lifejacket 2 Battery Replacement, Back Panel: passo 1, imagem 2 %32 Altec Lansing Mini Lifejacket 2 Battery Replacement, Back Panel: passo 1, imagem 3 %32
    • Use the spudger to remove the eight black pins from the front and back of the wire screens.
    Pergunte ao FixBot
    Comentar
  2. Altec Lansing Mini Lifejacket 2 Battery Replacement: passo 2, imagem 1 %32 Altec Lansing Mini Lifejacket 2 Battery Replacement: passo 2, imagem 2 %32 Altec Lansing Mini Lifejacket 2 Battery Replacement: passo 2, imagem 3 %32
    • Detach the eight secondary pins from the front and back of the wire mesh plates with a spudger.
    • Removing the secondary pins from the rubber casing is optional.
    Pergunte ao FixBot
    Comentar
  3. Altec Lansing Mini Lifejacket 2 Battery Replacement: passo 3, imagem 1 %32 Altec Lansing Mini Lifejacket 2 Battery Replacement: passo 3, imagem 2 %32
    • Remove both black and orange layers from the speaker body.
    Pergunte ao FixBot
    Comentar
  4. Altec Lansing Mini Lifejacket 2 Battery Replacement: passo 4, imagem 1 %32 Altec Lansing Mini Lifejacket 2 Battery Replacement: passo 4, imagem 2 %32 Altec Lansing Mini Lifejacket 2 Battery Replacement: passo 4, imagem 3 %32
    • Remove the single 7.8mm Phillips #2 screw from the mounting plate located under the device.
    • Slide the mounting plate out to remove it.
    Pergunte ao FixBot
    Comentar
  5. Altec Lansing Mini Lifejacket 2 Battery Replacement: passo 5, imagem 1 %32 Altec Lansing Mini Lifejacket 2 Battery Replacement: passo 5, imagem 2 %32
    • Pry off the wire mesh on both sides using a metal spudger.
    • Be gentle to avoid bending the mesh.
    Pergunte ao FixBot
    Comentar
  6. Altec Lansing Mini Lifejacket 2 Battery Replacement: passo 6, imagem 1 %32 Altec Lansing Mini Lifejacket 2 Battery Replacement: passo 6, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Using tweezers, remove the four rubber stoppers in each corner of the rear panel.
    Pergunte ao FixBot
    Comentar
  7. Altec Lansing Mini Lifejacket 2 Battery Replacement: passo 7, imagem 1 %32
    • Remove the four 13.7mm Phillips #1 screws located underneath the rubber stoppers.
    Pergunte ao FixBot
    Comentar
  8. Altec Lansing Mini Lifejacket 2 Battery Replacement: passo 8, imagem 1 %32
    • Pull the case apart to access the interior components.
    Pergunte ao FixBot
    Comentar
  9. Altec Lansing Mini Lifejacket 2 Battery Replacement: passo 9, imagem 1 %32 Altec Lansing Mini Lifejacket 2 Battery Replacement: passo 9, imagem 2 %32 Altec Lansing Mini Lifejacket 2 Battery Replacement: passo 9, imagem 3 %32
    • To remove the back panel, gently pull out its wire harness.
    Pergunte ao FixBot
    Comentar
  10. Altec Lansing Mini Lifejacket 2 Battery Replacement, Battery: passo 10, imagem 1 %32 Altec Lansing Mini Lifejacket 2 Battery Replacement, Battery: passo 10, imagem 2 %32 Altec Lansing Mini Lifejacket 2 Battery Replacement, Battery: passo 10, imagem 3 %32
    • Disconnect the battery from the motherboard.
    • The battery is not secured within the case and can be removed after detaching its wiring from the circuit board.
    Pergunte ao FixBot
    Comentar
Conclusão
8 outras pessoas executaram este guia.
Stephen Albrecht
Membro desde: 02/14/18
1.053 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S3-G2, Nance Spring 2018 Membro de USF Tampa, Team S3-G2, Nance Spring 2018
USFT-NANCE-S18S3G2
4 Membros
Autoria de 4 guias
13Comentários do guia
Where can you get the batteries? Altec Lansing doesn’t carry them.
alanp5 - Responder Compartilhar
Search for MCR18650 battery. They are available.
F Hickisch - Responder Compartilhar
Hickisch, I appreciate your guide on replacing this battery, but I beg to differ that replacement batteries are “available.” I keep getting sent batteries with 3-wire connectors instead of 2-wire. Plz send me a link, plz. Gracias.
rudy.ch.garcia - Responder Compartilhar
Sounds like you need to find another source instead of aliexpress or ebay. Digikey has them with the correct 2 wire connection. It's just a standard 18650 battery with the wires spot welded to the positive and negative terminals. Anything with a 3rd wire is likely meant as a charge sensing wire for a batter that has on board circuitry.
rchuncleskeleton - Responder Compartilhar
for the mini life jacket 3, the motherboard is upside down so you need to remove it to unplug the battery.
Edgar Corral (Tramarius) - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 25
Últimos 30 dias: 102
Ao todo: 24,449
